Imposed velocity profile
JamesMcNaughton
Re: Imposed velocity profile
You need to set the other velocity values at the inlet. And if running turbulence need to set those quantities too.
stage75
Yes James I use the (K-epsilon regime of turbulence)!
I changed the value of velocity but I have the same error message
The is other parameters to define when I impose a inlet?Some boundary definitions are incomplete or incorrect:
JamesMcNaughton
Have you set all the variables at the inlet?
stage75
precisely, I wonder if there are other variables to enter at the inlet apart the velociy,
My code at the inlet is:
I miss things to define?
call getfbr('Face_155', nlelt, lstelt)
do ilelt = 1, nlelt
ifac = lstelt(ilelt)
iel = ifabor(ifac)
do iphas = 1, nphas
itypfb(ifac,iphas) = ientre
rcodcl(ifac,iv(iphas),1) = 0.5d0
enddo-
JamesMcNaughton
Sorry yes that is what I had meant... you need to set the other velocity variables (iu, iv, iw) and turbulent quantities (for your case ik, iep).
stage75
Thank you very much for your reply and your help James,
I redefined my velocity as follows:
By cons I have no idea on how to define the parameters of turbulences (ik and iep), (I chose the K-epsilon model), mybe its like this:
I don't know, really, how to proceed!!
do ilelt = 1, nlelt
iel = ifabor(ifac)
do iphas = 1, nphas
rcodcl(ifac,iu(iphas),1) = 0.0d0
rcodcl(ifac,iw(iphas),1) = 0.0d0
enddoCode: Select all
rcodcl(ifac,ik(iphas),1)
rcodcl(ifac,iep(iphas),1)-
JamesMcNaughton
Yes like that, have a look at the examples in usclim it shows you how to define them there.
stage75
THanks James for your ideas !
Is this different définition are general and by default, I can use it dirrectly:
Its important to define "dh" (hydraulic diameter"
rhomoy = propfb(ifac,ipprob(irom(iphas)))Code: Select all
!uref2 = rcodcl(ifac,iv(iphas),1)**2 + omegay**2*0.075**2
!uref2 = max(uref2,1.d-12)Thanks
JamesMcNaughton
The examples are (I think) for a pipe flow based on a hydraulic diameter (keendb subroutine I think it is called), the second example uses the turbulence intensity (keenin). You can try setting your turbulence using them if you like but they are unlikely to give you the correct inlet turbulence for your case. If you have experimental data they may have given you information (eg turbulent intensity / length-scales) that you can use. If you're not familiar with this a good starting point might be http://www.cfd-online.com/Wiki/Turbulence_modeling
although you'll get more out of a text book on turbulence modelling. I am afraid that is as much as I can help with this as I am no expert in turbulence modelling myself.
Your questions:
Do you set "dh" ? Yes if you are using it (in the keenin / keendb routines or elsewhere).
rhomoy - this is the fluid density.
uref2 - in the example this is u^2 + v^2 + w^2 for use in the keenin / keendb subroutines but you have changed it.
Good luck!
James
Your questions:
Good luck!
James
stage75
Thank you verry much James,
I will read carefully the link you gave me and at the same time I run a simulation (on a larger time scale) with the parameters that you suggested to me, in goal to see if the result is consistent..
