I have still the same problem when I run a case, yes.
To be honest, I don't really know if I am using a batch system, I think yes. I have set the last Ubuntu on a virtual machine. Also, I am not quite sure to know the right command to do what you write me above. Should I run code saturne from my study case?
Thank you both,
Damien
Issues installation CS_2.1.1 with Salome 6.4
Jacques Fontaine
Re: Issues installation CS_2.1.1 with Salome 6.4
Hello, You probably do not use a batch system (batch systems are usually used on clusters or supercomputers). Yvan suspects a problem with your Python install/version. So, could you check your Python version (python --version)? And could you attach the new config.log? Yes, you can run Code_Saturne from your study case (code_saturne run / code_saturne run --help for more options or SCRIPT/runcase or in the GUI). To be sure that there is no error in your study, you can follow the step by step tutotials distributed with the source code (if the latex guides are compiled run the command: code_saturne info -g tutorial; if not, you can download the documentation on the website: http://research.edf.com/research-and-the-scientific-community/software/code-saturne/download-code-saturne-80059.html).
JF
JF
Damien Charreron
Well my python version is the 2.6, but I am not sure that I am using the one of Salome because I wasn't able to set it during the installation (problem such as version of python 2.6 >= "2.4" error: too old). S I attached you my config.log.
Also, I tried with the case from the code_saturne examples. After running code_saturne run, I got this:
damien@ubuntu:~$ code_saturne run --case=/home/damien/etudetest
File "/home/damien/CodeSaturne/code_saturne-2.1.1/code_saturne-2.1.1/bin/code_saturne", line 49, in <module>
retcode = cs.execute()
File "/home/damien/CodeSaturne/code_saturne-2.1.1/code_saturne-2.1.1/lib/python2.6/site-packages/code_saturne/cs_script.py", line 62, in execute
File "/home/damien/CodeSaturne/code_saturne-2.1.1/code_saturne-2.1.1/lib/python2.6/site-packages/code_saturne/cs_script.py", line 114, in run
File "/home/damien/CodeSaturne/code_saturne-2.1.1/code_saturne-2.1.1/lib/python2.6/site-packages/code_saturne/cs_run.py", line 191, in main
save_results=save_results)
File "/home/damien/CodeSaturne/code_saturne-2.1.1/code_saturne-2.1.1/lib/python2.6/site-packages/code_saturne/cs_case.py", line 1718, in run
mpi_environment)
File "/home/damien/CodeSaturne/code_saturne-2.1.1/code_saturne-2.1.1/lib/python2.6/site-packages/code_saturne/cs_case.py", line 1244, in prepare_data
self.set_result_dir(self.run_id)
File "/home/damien/CodeSaturne/code_saturne-2.1.1/code_saturne-2.1.1/lib/python2.6/site-packages/code_saturne/cs_case.py", line 471, in set_result_dir
if not os.path.isdir(self.result_dir):
File "/home/damien/salome/Python-2.6.6/lib/python2.6/genericpath.py", line 41, in isdir
st = os.stat(s)
TypeError: coercing to Unicode: need string or buffer, NoneType found
mpi_environment)
st = os.stat(s)
- config.txt
- (220.76 KiB) Downloaded 456 times
If you have a case directory inside your etudetest directory, try running:
code_saturne run --case=/home/damien/etudetest/<case> --param test.xml
instead of
This depends on whether you created the case with the --study or --case option, but is again related to providing the correct directory structure for Code_Saturne
Or better, simply "cd" inside your case's DATA or SCRIPTS directory, and run:
code_saturne run --param test.xml
In any case, if you have an xml file, you must indicate is using the --param or -p option when using "code_saturne run"
instead of
Damien Charreron
WOWW!!! Thank you, It's working well, you rock!
It took me so much time to understand everything!
Now I have my new game for 2012!
Merci encore!
Merci encore!
Damien Charreron
I am triying installing the last version of cs. However I have met a problem I didn't see before:
/usr/bin/ld: cannot find -lz
collect2: ld returned 1 exit status
I tried running this: ln -s /etc/ld.so.conf /usr/bin/ and then ldconfig but it didn't solve the pb
I have attached my installation.log.
- install_saturne.log
- (151.57 KiB) Downloaded 402 times
It is strange that you encounter this issue, as a minor change was made so that the path oder in the link would be more logical (especially to avoid link issues with static builds, which need a stricter order).
Check that "libz" (or Zlib) is installed on your system, also with the "-devel" part of the package. If you have a mix of 32 and 64 bit packages, also check that the version you have is the correct one. In this case, the problem might be due to using prerequisites from SALOME, so you may either try to source the SALOME prerequisites environment file (salome.sh or "prerequis.sh" from the SALOME tree).
To have a build with CFDSTUDY, add --with-salome-<path to SALOME kernel> (though this is not related to this issue, as the SALOME prerequisites are sourced only for the SALOME packages, not the rest of the code).
Torben Andersen
This is how I got around installing code_saturne 2.1.4 with Salomé 6.4 (even if there may be more straight or elegant ways ...) on Linux Mint 9 (Ubuntu 10.04 Lucid Lynx based). Commands are in bold and may be copy-pasted to a shell command line for convenience. Doing so requires that your install paths are like mine and that you have write acces to these locations (su root if required):
1. Install Salome 6.40 (in /opt/Salome-V6_4_0-LGPL-i686)
2. Search and remove *.la files in the Salomé tree: find /opt/Salome-V6_4_0-LGPL-i686 -name \*.la -exec rm {} \;
3. Install code_saturne using the install_saturne.py script and these settings in the setup file:
4. Test the saturne installation and the saturne gui. If it works modify to enable Salome integration:
5. Change working directory to code_saturne build root: cd /opt/saturne/installer/code_saturne-2.1.4.
6. Reconfigure code_saturne-2.1.4: ./configure --prefix=/opt/saturne/code_saturne-2.1.4 --with-cgns=/opt/saturne/cgnslib-2.5.5 --with-hdf5=/opt/Salome-V6_4_0-LGPL-i686/prerequisites/Hdf5_184 --with-med=/opt/Salome-V6_4_0-LGPL-i686/tools/Medfichier_304 --with-salome=/opt/Salome-V6_4_0-LGPL-i686 --cache-file=/dev/null --srcdir=/opt/saturne/installer/code_saturne-2.1.4/
7. Compile and install: make install
8. IF errors in compiling/installing the Python scripts of the CFDSTUDY are reported, this command may finish what went wrong: for f in /opt/saturne/installer/code_saturne-2.1.4/salome/cfd_study/src/CFDSTUDYGUI/ui_CFDSTUDYGUI_QProcessDialog.py /opt/saturne/installer/code_saturne-2.1.4/salome/cfd_study/src/CFDSTUDYGUI/ui_CopyDialog.py /opt/saturne/installer/code_saturne-2.1.4/salome/cfd_study/src/CFDSTUDYGUI/ui_ECSConversionDialog.py /opt/saturne/installer/code_saturne-2.1.4/salome/cfd_study/src/CFDSTUDYGUI/ui_EnvSettingsDialog.py /opt/saturne/installer/code_saturne-2.1.4/salome/cfd_study/src/CFDSTUDYGUI/ui_GUIActivationDialog.py /opt/saturne/installer/code_saturne-2.1.4/salome/cfd_study/src/CFDSTUDYGUI/ui_InfoDialog.py /opt/saturne/installer/code_saturne-2.1.4/salome/cfd_study/src/CFDSTUDYGUI/ui_RunCaseDialog.py /opt/saturne/installer/code_saturne-2.1.4/salome/cfd_study/src/CFDSTUDYGUI/ui_SetTreeLocationDialog.py ; do /usr/bin/install -c $f /opt/saturne/code_saturne-2.1.4/lib/python2.6/site-packages/salome/`basename $f` ; done ;
The special steps are 5, 6 and 7 I found no other way to enable my Salomé installation. Even with the environment parameter $ROOT_SALOME correctly set and exported.
My .bashrc was modified to include these lines:
The if's are necessary here in .bashrc to avoid the $PATH being extended on every new shell.
download Yes
prefix /opt/saturne
cgns None yes yes
hdf5 /opt/Salome-V6_4_0-LGPL-i686/prerequisites/Hdf5_184 auto no
med /opt/Salome-V6_4_0-LGPL-i686/tools/Medfichier_304 auto no
mpi None auto no
libxml2 None auto no5. Change working directory to code_saturne build root: cd /opt/saturne/installer/code_saturne-2.1.4.
# set variables for Code_Saturne and Code_Aster #============================================================================
CSPATH=/opt/saturne/code_saturne-2.1.4/bin
CAPATH=/opt/aster/outils ROOT_SALOME=/opt/Salome-V6_4_0-LGPL-i686
HDF5HOME=${ROOT_SALOME}/prerequisites/Hdf5_184
LD_LIBRARY_PATH=${HDF5HOME}/lib:${LD_LIBRARY_PATH}
MED2HOME=${ROOT_SALOME}/tools/Medfichier_304
LD_LIBRARY_PATH=${MED2HOME}/lib:${LD_LIBRARY_PATH}
export LD_LIBRARY_PATH
if [ -z `which code_saturne` ]
then
export PATH=$PATH:$CSPATH
fi
if [ -z `which astk` ]
then
export PATH=$PATH:$CAPATH
fiThe if's are necessary here in .bashrc to avoid the $PATH being extended on every new shell.
