Kelvin-Helmholtz instability
Jean Deschodt
Post by Jean Deschodt »
A simplified Kelvin Helmholtz instability was simulated. Dry air filled up the upper half of the domain, and humid air the lower half. A 4% difference of density was assumed between the two gas. 2 m/s difference in velocity across the interface was fixed. The inlet velocity of the dry air was perturbed with a sinusoidal signal in order to generate the instability.
Jean Deschodt
Re: Kelvin-Helmholtz instabilities
Files to reproduce the case with Code_Saturne 2.0-rc1 :
usiniv-f90.gz
(2.91 KiB) Downloaded 7377 times
kelvin-med.gz
(1.18 MiB) Downloaded 7551 times
instabilities-xml.gz
(1.88 KiB) Downloaded 7448 times
David Monfort
Re: Kelvin-Helmholtz instability
Post by David Monfort »
Hello Jean,
This is a really nice example here!
However, you might have better results with symmetries farther from the middle (haven't try though...). It seems you have some "blocking effect" due to the presence of the symmetries at bottom and top.
David
Jean Deschodt
I redo the computation with a wider inlet. Indeed, it changes the flow a little.  I redo also the set up without usini1.f90: everything was done by the GUI. I upload the new files below.
kelvin-xml.gz
(1.93 KiB) Downloaded 7365 times
kelvin-helmholtz-med.gz
(3.56 MiB) Downloaded 7698 times
Claus Andersen
Post by Claus Andersen »
I thought the attached picture was relevant to this post went I came across it - I assume it's the described phenomena?
Claus
