Parallelism issue in uselrc
I am using special physics electric arcs in Saturne V2-rc2. I try to use the restriking model.
I get some troubles with parallelism when I want to get the restriking position point. My code is working in a single processor, but it does not give me the good position in multi-processors, probably because of the local variable emax.
Here is the code :
do iel = 1, ncel
if(xyzcen(3,iel) .gt. 2.d-3 .and. xyzcen(3,iel) .lt. 70.d-3) then
xelec = propce(iel,ipcdc1)/propce(iel,ipcsig)
yelec = propce(iel,ipcdc2)/propce(iel,ipcsig)
zelec = propce(iel,ipcdc3)/propce(iel,ipcsig)
w1(iel) = sqrt ( xelec**2 + yelec**2 + zelec**2 )
amex = min(amex,w1(iel))
aiex = max(aiex,w1(iel))
endif
if(irangp.ge.0) then
call parmin (amex)
call parmax (aiex)
endif
if(aiex .ge. econs) then
iclaq = 1
ntdcla = ntcabs
do iel = 1, ncel
if(w1(iel).gt.emax) then
xclaq = xyzcen(1,iel)
yclaq = xyzcen(2,iel)
zclaq = xyzcen(3,iel)
emax = w1(iel)
endif
I tried some modifications but I get floating point exception. How can i overcome this parallelism issue ?
Here is the code :
do iel = 1, ncel
endif
call parmin (amex)
call parmax (aiex)
endif
iclaq = 1
ntdcla = ntcabs
do iel = 1, ncel
emax = w1(iel)
endif
Re: Parallelism issue in uselrc
Could you send the complete routine?
Mickaël Hassanaly
Mickaël Hassanaly
The complete routine is attached to this post.
- uselrc.f90
- (25 KiB) Downloaded 249 times
So far away, i don't see any mistakes. But when you do "write(nfecra,*) 'xclaq', xclaq, yclaq,zclaq,ntdcla", all processors are able to write in the listing. So i think you have to either request the N-processor listings to be output or to leave only one processor to write into nfecra. First solution to verify my theory is better and if it's correct, you should improve your routine.
Mickaël Hassanaly
Mickaël Hassanaly
OK, so what is the command for n-processors listings output ?
you can either user the GUI and modify the options of the runcase or fill ARG_CS_OUTPUT="--logp 1" in the runcase.
Mickaël
Mickaël
OK, I tested it. The values I am interested in (Emax, xclaq, yclaq, zclaq) are on the processor #7, and the listing gave me the values of the first processor.
So, How can I be sure that code_saturne will use thes values instead of the one of processor #1 ? And how to display the good values (the real Emax and corresponding x,y,zclaq) in the main listing ?
Alexandre
Alexandre
I tried the PARCOM subroutine to make the processors communicate with each other, but the calculation seems to block (no error message but stay at same time step for hours).
Is it the good subroutine to use, ans if yes, can I use it like this in a loop :
iclaq = 1
ntdcla = ntcabs
do iel = 1, ncel
emax = w1(iel)
call parcom (emax)
endif
endif
write(nfecra,*) 'claquage ', ntcabs, emax
endif
iclaq = 1
ntdcla = ntcabs
do iel = 1, ncel
emax = w1(iel)
call parcom (emax)
endif
endif
endif
PARCOM is a collective synchronization routine, to be called for fields defined on cells, not local 0-d values.
Check in cs_parall.h for function documentation, but PARMAX would be more useful in your case.
And here again, it is a collective function, to be called the same number of times by all ranks, so it should never be called in a loop on cells, but after the loop. If necessary, do a first loop to obtain the maximum, synchronize it with PARMAX, then do a second loop using the global value.
Hello, Thanks for the answer. Actually, when I use 2 loops, I get a SIGFPE signal with 8 processors (on processors #3 and #5) but not with a single processor... I have the same pb with 2 processors. Code_saturne seems to catch the good values on processor #7 but crash before using it. I join the files.
Alexandre
Alexandre
- listing_n0003.txt
- (52.56 KiB) Downloaded 238 times
- error_n0005.txt
- (638 Bytes) Downloaded 271 times
- error_n0003.txt
- (638 Bytes) Downloaded 237 times
