I want to try the MEI in 2.0-rc1. I tried but found, for example, on the 'Fluid properties' page of the GUI, the 'user law' option is still grey, and as such I cannot click the following button either.
I newly compiled and installed 2.0-rc1. The install procedure was recorded into my post 'http://code-saturne.blogspot.com/2010/03/installation-of-codesaturne-20-rc1-on.html'
I compiled MEI in and I am not sure whether I need to configure anything more to enable the MEI options.
Many thanks in advance.
Wayne
How to use MEI in 2.0-rc1
Brennan Sharp
Re: How to use MEI in 2.0-rc1
When I build mei, I told the configure script explicitly where to find the bft installation. If I remember correctly, the script didn't find it, and said so while running. although I'm not sure whether the compilation will fail without bft.
i.e. ./configure --with-bft=$INSTALLROOT
My $INSTALLROOT is /usr or /usr/local depending on how I'm installing.
David Monfort
Hello Wayne,
The graphical interface needs to find the Python module mei to enable the definition of user law from itself. You may need to provide Code_Saturne configure with the following option to ensure it (the Python module) is properly found: --with-mei=/usr/local (like for the preprocessor).
Actually, I've never installed the code without specifying a --prefix option for the different packages, so I don't know which options to give...
Let me know if it works (or not...) and if not, could you attach the result of the command code_saturne config ? And perhaps also, the result of locate _mei.so (with underscore), if any.
David
ps : I'll look read more thoroughly your guide asap and provide you with some feedback pps: I don't think you can compile MEI without BFT in this specific version of the library ; here, the BFT library may be found thanks to ldconfig, but perhaps not the Python module
David
salad
Thanks for your help :)
I used ./configure
to configure mei without specifying anything, but it seems it can find the bft, because of the output saying
checking for library containing pow... -lm
checking for bft version >= "1.0.0"... compatible bft version found
checking for ANSI C header files... (cached) yes
I didn't specify the mei location when ./configure ncs, because for the first time when I didn't have mei compiled and installed, the ./configure complained about the absence of mei. Please see the piece, from the config.log
of ncs, below, and I think ncs found mei and would use it.
configure:15854: checking mei_evaluate.h usability
configure:15854: gcc -c -std=c99 -funsigned-char -pedantic -W -Wall -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wnested-externs -Wunused -Wfloat-equal -D_POSIX_SOURCE -DNDEBUG conftest.c >&5
configure:15854: $? = 0
configure:15854: result: yes
configure:15854: checking mei_evaluate.h presence
configure:15854: gcc -E -D_POSIX_SOURCE -DNDEBUG conftest.c
configure:15854: checking for mei_evaluate.h
configure:15861: checking for mei_evaluate in -lmei
configure:15886: gcc -o conftest -std=c99 -funsigned-char -pedantic -W -Wall -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wnested-externs -Wunused -Wfloat-equal -D_POSIX_SOURCE -DNDEBUG -Wl,-export-dynamic -O conftest.c -lmei -lmei -lbft >&5
conftest.c:46: warning: function declaration isn't a prototype
conftest.c:49: warning: function declaration isn't a prototype
configure:15886: $? = 0
configure:15895: result: yes
The output of code_saturne config
is
$ code_saturne config
Directories:
dirs.prefix = /usr/local
dirs.exec_prefix = /usr/local
dirs.bindir = /usr/local/bin
dirs.includedir = /usr/local/include
dirs.libdir = /usr/local/lib
dirs.datarootdir = /usr/local/share
dirs.datadir = /usr/local/share
dirs.pkgdatadir = /usr/local/share/ncs
dirs.docdir = /usr/local/share/doc/ncs
dirs.pdfdir = /usr/local/share/doc/ncs
Auxiliary information:
dirs.ecs_bindir = /usr/local/bin
dirs.syrthes_prefix =
MPI library information:
mpi_lib.type = OpenMPI
mpi_lib.bindir = /usr/lib/openmpi/bin
mpi_lib.libdir = /usr/lib/openmpi/lib
Compilers and associated options:
cc = gcc
fc = gfortran
cppflags = -D_POSIX_SOURCE -DNDEBUG -I/usr/lib/openmpi/include -I/usr/include/libxml2
cflags = -std=c99 -funsigned-char -pedantic -W -Wall -Wshadow -Wpointer-arith -Wcast-qual -Wcast-align -Wwrite-strings -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wnested-externs -Wunused -Wfloat-equal -funroll-loops -O2 -Wuninitialized -march=i686
fcflags = -x f95-cpp-input -Wall -Wno-unused -D_CS_FC_HAVE_FLUSH -O
ldflags = -L/usr/lib/openmpi/lib -Wl,-export-dynamic -O
libs = -lfvm -lm -lmedC -lhdf5 -lfvm_coupl -lmei -lbft -lz -lmpi -lxml2 -lcblas -latlas -L/usr/lib/gcc/i486-linux-gnu/4.4.1 -L/usr/lib/gcc/i486-linux-gnu/4.4.1/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/i486-linux-gnu/4.4.1/../../.. -L/usr/lib/i486-linux-gnu -lgfortranbegin -lgfortran -lm -ldl
rpath = -Wl,-rpath -Wl,
Compilers and associated options for SYRTHES build:
cc =
fc =
cppflags =
cflags =
fcflags =
ldflags =
libs =
The output of locate _mei.so
is (/home/salad is my user home directory and mei-1.0.1 is the source code location, from which I compile and install mei)
$ locate _mei.so
/home/salad/saturne/mei-1.0.1/swig/.libs/_mei.so
/home/salad/saturne/mei-1.0.1/swig/.libs/_mei.so.0
/home/salad/saturne/mei-1.0.1/swig/.libs/_mei.so.0.0.0
/home/salad/saturne/mei-1.0.1/swig/.libs/_mei.so.0.0.0T
/usr/local/lib/python2.6/dist-packages/mei/_mei.so
/usr/local/lib/python2.6/dist-packages/mei/_mei.so.0
/usr/local/lib/python2.6/dist-packages/mei/_mei.so.0.0.0
Anyway, as you advised, I will try to compile mei again with specifying bft. If problem is solved, I will report here :)
Many thanks again.
Wayne
ps : Take your time and thanks a lot for your time on the posts :p
I used ./configure
is
Directories:
cc = gcc
fc = gfortran
cc =
fc =
cppflags =
cflags =
fcflags =
ldflags =
libs =
$ locate _mei.so
Many thanks again.
Wayne
salad
I just re ./configure and compile the MEI and ncs souce codes and found the problem has been solved.
Firstly, I specified --with-bft=/usr/local for mei. (I use /usr/local for all self compiled software)
Then I compiled ncs again without specifying mei location. I thought ncs could find it, because the output said
Configuration options: use debugging code: false use graphical user interface: yes MPI (Message Passing Interface) support: yes OpenMP support: no BLAS (Basic Linear Algebra Subprograms) support: yes Libxml2 (XML Reader) support: yes MEI (Mathematical Expressions Interpreter) support: yes SYRTHES 3 coupling support: no IP socket support (for SYRTHES 3 or CFD_Proxy): yes Dynamic loader support (for YACS): yes
However as you predicted, the problem was still there.
Finally I specified --with-mei=/usr/local and re-compiled the source code again. I could then use the option 'user law' and open the edit dialog.
I will try to use the function tonight since my example case is saved at home.
Many thanks for all your help.
Wayne
Wayne
David Monfort
Great !
Actually, you don't need to precise anything like --with-bft or --with-mei as long as what you are looking for is only the dynamic libraries (libmei.so and libbft.so). And this is indeed what says the ncs configure output:
MEI (Mathematical Expressions Interpreter) support: yes <=> cs_solver can read XML file with formulae thanks to the libmei.so library
But, the other side of MEI is _mei.so and its companion mei.py (the Python module). These ones are handled differently, and obviously not found by the standard method (see the code of the "code_saturne" script) when not specifying --with-mei.
Anyway, now it seems to work ;)
David
David
salad
Thanks to your help, I finished another post on MEI.
MEI is easy to use and works like a charm!
Please read when you have time and any comments are welcome.
Wayne
Wayne
David Monfort
Hi Wayne,
Nice feedback again ;) No specific comment here... everything's fine. Just keep playing with MEI in the different available places :)
David
David
