Reading UNV mesh (SALOME) with Saturne.
Chebli Rezki
I created an Hydrofoil geometry and I meshed it in using SALOME 5.1.3. I exported the UNV file (knowing that saturne code can't read MED mesh file).
After checking the mesh, I launched the calculation and I had this error message:
Error running the preprocessor. Check preprocessor log (listpre) for details. ******************************************** Error in preprocessing stage. ********************************************
listpre file is attached.
Thank you in advance.
Rezki
Rezki
- listpre-06210954.txt
- (2.85 KiB) Downloaded 521 times
Re: Reading UNV mesh (SALOME) with Saturne.
You have the explanation for your error at line 78 of your "listpre" file.
David Monfort
Indeed Code_Saturne only handles volumic elements. To use a 2d-mesh, you need to extrude the mesh (a 1-cell extrusion, with symmetry applied as boundary conditions) along the right direction (z in your case).
David
David
Chebli Rezki
Hi David,
Thank you for your help, I extrude the mesh in SALOME and it works. But When I introduced boundary conditions while keeping the color references (selection criteria) which appears in SALOME (28 and 35 for inlet for example), the code don't know these colors. and I have an error message :
Le groupe ou attribut "28" figurant dans le critère de sélection: "28 and 35" ne correspond à aucune face de bord. Please, How to make to know the color references associated to each condition through Saturne ? listing file is attached. Regards. Rezki
- listing-06221028.txt
- (29.23 KiB) Downloaded 512 times
The selection criteria apply for each face, so "28 and 35" would select only faces that belong to 2 (overlapping) groups with colors 28 and 35. To select either 28 or 35, use "28 or 35".
Chebli Rezki
I try to use "or" instead of "and" but I have same error for each boundary conditions which I introduced :
Code_Saturne : /home/rezki/saturne/installer/ncs-2.0.0-rc1/src/base/cs_gui_boundary_conditions.c:1090 : Avertissement
Le groupe ou attribut "28" figurant dans le critère de sélection: "28 or 35" ne correspond à aucune face de bord.
Le groupe ou attribut "4" figurant dans le critère de sélection: "4" ne correspond à aucune face de bord.
Le groupe ou attribut "21" figurant dans le critère de sélection: "21 or 14" ne correspond à aucune face de bord.
Le groupe ou attribut "46" figurant dans le critère de sélection: "46 or 49" ne correspond à aucune face de bord.
More informations about the mesh quality is attached here.
Regards.
Rezki
Regards.
Rezki
- mesh_informations.txt
- (17.01 KiB) Downloaded 547 times
Looking at the beginning of you mesh information (the equivalent of "listpre"), it seems that you have groups Symmetry, Walls_3D, inlet_3D, or outlet_3D, and not 28, 35, ...
I am not sure what color references you used in SALOME: you may assign a color to a group, and that should appear under Code_Saturne (it was useful in the past, when colors were easier to handle then groups in Code_Saturne, but since version 1.3, the group name should be preferable). You may also set colors for visualization, but those are not passed to Code_Saturne.
In any case, prefer group names to colors in Code_Saturne when available (such as when meshing with SALOME).
Chebli Rezki
Ok, so you checked my mesh file and you find that I have just one color (color
7) for all groups, knowing that I created four groups in SALOME
(inlet_3D, outlet_3D, Walls_3D and Symmetry)
Please, which is an exactly criteria which I should to introduced in
"Selection criteria" ? (reference face which appears in
SALOME mesh, color, Famille, groups......)
If the answer is "color", why I have just one (color 7) ?
Rezki
Rezki
David Monfort
Rezki,
I don't why you have a single color, but this doesn't matter as you have group names.
As Yvan told you "In any case, prefer group names to colors in Code_Saturne when available (such as when meshing with SALOME)" and as it is written in the user documentation "code_saturne info -g user" (page 31, chapter Face and cell mesh-defined properties and selection), you can directly use the group names.
So, just use inlet_3D for the inlet, outlet_3D for the outlet, ...
David
David
Chebli Rezki
The problem is resolved by using groups which I named inlet_3D,....
Yvan, David, I am grateful for your help, thank you very much.
Best regards.
Rezki
Best regards.
Rezki
