Dear support and users
Is there any way to set a velocity direction normal to the inlet without setting speed vector direction in uspcl.f90 file?
Norbert
Velocity direction normal to the inlet.
Re: Velocity direction normal to the inlet.
[edit: D. Monfort, 5 oct. 2010, correct code example]
Hi Norbert,
You should use the array rcodcl in uscpcl.f90 in order to specify the velocity direction. If you want specify, a normal direction you can use the surfbo array:
do ifac = 1,nfac
rcodcl(ifac, iu(iphas), 1) = -surfbo(1, ifac)
rcodcl(ifac, iv(iphas), 1) = -surfbo(2, ifac)
rcodcl(ifac, iw(iphas), 1) = -surfbo(3, ifac)
Of course you have to impose the flow rate with iqimp and qimpat.
Hi Norbert,
do ifac = 1,nfac
