my config: Red hat 2.6.18-194.el5 64 bits whit Code_saturne 2.01
in virtual machine VMWARE.
When i clik on " check mesh", i have this problem:
| Fin normale du Préprocesseur |
/usr/local/bin/cs_solver: symbol lookup error: /usr/local/lib/libfvm.so.0: undefined symbol: ompi_mpi_info_null
how can i resolv?
When i clik on
Re: When i clik on "check mesh"
What is the path of your MPI (Open MPI) install used with Code_Saturne ? Do you have multiple MPI installs ?
Eric Belin
the path of MPI:
CS_MPI_PATH=/usr/lib/openmpi/1.4-gcc/bin
2 installations of MPI, one with the installer of code_saturne 1.33 and another with code_saturne 2.0.1
Eric
the path of MPI:
Eric
Re: When i clik on
I suspect the MPI library loaded by Code_Saturne 2.0.1 is not the one with which it was compiled. This may happen if you have an LD_LIBRARY_PATH set for Code_Saturne 1.3, or if its version of OpenMPI is in system paths and 2.0's is not.
You should try to
You should try to
in your .profile file to see if it solves the issue.export LD_LIBRARY_PATH=/usr/lib/openmpi/1.4-gcc/lib:$LD_LIBRARY_PATH
Eric Belin
Re: When i clik on
no change with:
Kernel : /usr/local
Preprocessor : /usr/local/bin
HOMARD :
CS_MPI_PATH :
PATH : /opt/syrthes3.4.3/bin:/opt/syrthes3.4.3/bin/Linux_x86_64:/opt/aster/public/hdf5-1.6.9/bin:/opt/aster/public/med-2.3.6/bin:/opt/metis-4
.0:/opt/Saturne_1.3.3/Noyau/ncs-1.3.3/bin:/opt/Saturne_1.3.3/Enveloppe/ecs-1.3.3/bin:/opt/syrthes3.4.3/bin:/opt/syrthes3.4.3/bin/Linux_x86_64:/opt/aster/publ
ic/hdf5-1.6.9/bin:/opt/aster/public/med-2.3.6/bin:/opt/metis-4.0:/opt/Saturne_1.3.3/Noyau/ncs-1.3.3/bin:/opt/Saturne_1.3.3/Enveloppe/ecs-1.3.3/bin:/usr/kerbe
ros/sbin:/usr/kerberos/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/X11R6/bin:/root/bin
Eric
no change with:
I see in file RESU/summary.xxxx, no define for CS_MPI_PATH: ??export LD_LIBRARY_PATH=/usr/lib/openmpi/1.4-gcc/lib:$LD_LIBRARY_PATH
Kernel : /usr/local
HOMARD :
CS_MPI_PATH :
Eric
Do you have the config.log files from the build directories of the FVM library and of the NCS kernel ?
Eric Belin
Re: When i clik on file:///home/yvan/Code_Saturne/Web/old_forums_files/515868552/config_fvm.log
Add in attachment....
Eric
Eric
- config_fvm.log
- (71.23 KiB) Downloaded 286 times
- config_ncs.log
- (106.21 KiB) Downloaded 303 times
Re: When i clik on
What is the output of:
ldd /usr/local/lib/libfvm.so.0
and of:
nm /usr/local/lib/libfvm.so.0 | grep MPI
and finally:
ls /usr/local/lib/lib*mpi.* /usr/lib/lib*mpi.*
and of:
and finally:
