I use Code_Saturne version 2.0.1 and I use the usdpst.f90 subroutine to create a part, and the usvpst.f90 subroutine to post-treat this part.
I want to recover the value of interior faces centers of gravity (CDGFAC) on a finite numbers of points with a regular interval. For this, I try to use the PARAGV function to transform the interior faces local number into global number, but MPI doesn't like that. Do you think it's a table size problem? I join the usdpst.f90, the usvpst.f90, the .xml file (test_usv.xml).
Thanks in advance.
Best regards.
Pauline
Re: Problem with PARAGV function
Pauline Delteil
- usvpst.f90
- (18.81 KiB) Downloaded 279 times
- usdpst.f90
- (18.79 KiB) Downloaded 296 times
- test_usv-xml.xml
- (5.78 KiB) Downloaded 277 times
James McNaughton
paragv is for real arrays and I think you are using it for integers? Not sure if that would cause your problem but I needed something similar before so copied and pasted the paragv to a new one called paragw and changed the real argument to integer. Maybe it will help your problem so I've attached the files - just put them in SRC and call paragw instead of paragv.
James
James
- cs_parall.h
- (21.6 KiB) Downloaded 263 times
- cs_parall.c
- (39.83 KiB) Downloaded 292 times
Pauline Delteil
Hello James,
thank you for your answer. You are right, so I transform integers into reals because I am not entitled to change the src in the core.
Best regards.
Pauline
Best regards.
Pauline
James McNaughton
It only needs to be in the case SRC folder not the actual program source - Saturne's very clever in that respect, just place the files in the folder where you would put your other fortran files i.e. TEST_USV/TEST_MARIE/SRC.
James
James
