y+ calculation on rough walls
MaximeO
Post by MaximeO »
Does anyone knows how exactly is calculated the y+ on a rough wall (on code_saturne v8.0) ?
I have searched in the theory guide (https://www.code-saturne.org/documentat ... theory.pdf p.58-60) but the rough wall part doesn't really answer this question.
The thing is, when I'm looking at my results, the y+ computed by code_saturne doesn't correspond to the y+ I have calculated with the theoretical formula and the computed wall shear-stress, and there is a huge difference ( on code_saturne while I calculated ), but I may be missing a point here ?
Maxime
Re: y+ calculation on rough walls
This is probably computed in src/base/clptrg.f90. So it may be interesting to check/log/print the intermediate values used in its computation.
I'm not sure about the theory part, as there is both a legacy rough wall model, and a new one (continuous "smooth/rough" model). The newer model should be mostly equivalent to the old one in rough wall regions, but some details might change.
MaximeO
Post by MaximeO »
Thank you for your response.
I've checked the clptrg file, and apparently for rough walls it is computed as : (where is the distance from the centre of the wall-adjacent cell to the wall, and is the aerodynamic roughness length). This explain why I had such a low constant value of y+ along my coputational domain.
So now my question is : when we use wall functions, we need in theory to respect a y+ value of at least 20-30 to ensure having the second cell in the log-region. But as I said, the y+ computed by code_saturne is way smaller than the theoretical one (). So which one should I refer to ? This computed y+ isn't it finally just here for coding purposes and don't have any real physical meaning ?
Maxime
As far as I know, in the case of smooth walls, the y+ 20-30 rule applies to high-Reynolds wall laws. For low-Reynolds or "all-y+" wall laws, smaller y+ values are allowed.
I am not too sure about rough wall laws and would need to check with a colleague, but since they also include some specific modeling, chances are pretty high that indeed the y+ value has a "mathematical" role only.
It may also be interesting in your case to check results with the "smooth-rough" wall law (which, if I am not mistaken, is handled as a smooth wall in clptur.f90, with a user-provided boundary roughness field).
