AdamLarat
Posts: 16 Joined: Fri May 16, 2025 3:30 pm
Post
by AdamLarat » Mon Jun 30, 2025 6:02 pm
Now that I have been successfully able to run the Syrthes' coupling tutorial 3_DISKS, I have tried to report the procedure to my own test case. Both simulation (Syrthes and Saturne) work independently.
However, once I try to run the coupled simulation, the Syrthes process crashes with the following error:
Error during SYRTHES execution
ple_locator.c:3439: Fatal error.
Locator trying to use distant space dimension 1684426904
with local space dimension 0
syrthes: syr_cfd_coupling.c:219: _syr_error_handler: Assertion `0' failed.
[po21210:50962] *** Process received signal ***
[po21210:50962] Signal: Aborted (6)
[po21210:50962] Signal code: (-6)
[po21210:50962] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x13140)[0x7fb2fcb01140]
[po21210:50962] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x141)[0x7fb2fc952d51]
[po21210:50962] [ 2] /lib/x86_64-linux-gnu/libc.so.6(abort+0x123)[0x7fb2fc93c537]
[po21210:50962] [ 3] /lib/x86_64-linux-gnu/libc.so.6(+0x2240f)[0x7fb2fc93c40f]
[po21210:50962] [ 4] /lib/x86_64-linux-gnu/libc.so.6(+0x316d2)[0x7fb2fc94b6d2]
[po21210:50962] [ 5] ./syrthes(+0x3c965)[0x55cff6239965]
[po21210:50962] [ 6] /home/alarat/Codes/Carambarre/libs/code_saturne-8.0.4//lib/libple.so.2(ple_error+0x7e)[0x7fb2fcc3d62e]
[po21210:50962] [ 7] /home/alarat/Codes/Carambarre/libs/code_saturne-8.0.4//lib/libple.so.2(ple_locator_extend_search+0x222)[0x7fb2fcc42062]
[po21210:50962] [ 8] /home/alarat/Codes/Carambarre/libs/code_saturne-8.0.4//lib/libple.so.2(ple_locator_set_mesh+0x278)[0x7fb2fcc48b28]
[po21210:50962] [ 9] ./syrthes(+0x3e080)[0x55cff623b080]
[po21210:50962] [10] ./syrthes(+0x3f023)[0x55cff623c023]
[po21210:50962] [11] ./syrthes(+0x3b1ad)[0x55cff62381ad]
[po21210:50962] [12] ./syrthes(+0xddd6)[0x55cff620add6]
[po21210:50962] [13] ./syrthes(+0x5fba)[0x55cff6202fba]
[po21210:50962] [14] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xea)[0x7fb2fc93dd7a]
[po21210:50962] [15] ./syrthes(+0x628a)[0x55cff620328a]
[po21210:50962] *** End of error message ***
Do you have any idea of what is going wrong? Especially concerning these "space dimensions" !
You can find the whole test case attached.
Thanks a lot!
MyCoupling.tgz
(3.06 MiB) Downloaded 1492 times
Posts: 4299 Joined: Mon Feb 20, 2012 3:25 pm
Post
by Yvan Fournier » Tue Jul 01, 2025 11:19 am
The logging of the space dimension seems to be a bug, but I suspect your issue is that you have a 2D domain in Syrthes, and a 3D one in code_saturne. In the 3D disks example (whose reference setup should be updated), the "2D projection" option in the conjugate heat transfer section is set, which allows aligning the 3D computation with the 2D one.
AdamLarat
Post
by AdamLarat » Tue Jul 01, 2025 11:25 am
Thank you for your answer.
In my setup.xml Saturne's config file, I have the following section :
<conjugate_heat_transfer>
<external_coupling>
<syrthes>
<projection_axis>Z</projection_axis>
<selection_criteria>1</selection_criteria>
<syrthes_name>SYRTHES</syrthes_name>
<verbosity>0</verbosity>
<visualization>1</visualization>
</syrthes>
<syrthes_instances>
<instance name="SOLID">
<coupled_boundary label="Barre1_P1"/>
</instance>
</syrthes_instances>
</external_coupling>
</conjugate_heat_transfer>
With the projection line "<projection_axis>Z</projection_axis>".
Is this what you are talking about or is it something else ?
AdamLarat
Post
by AdamLarat » Tue Jul 01, 2025 11:35 am
All right! I have been able to run the simulation by rearranging the <conjugate_heat_transfer> as:
<external_coupling>
<syrthes_instances>
</instance>
<tolerance>0.1</tolerance>
It is still not clear for me why, but at least it is working!
Thanks!
