I am trying to understand how to restart calculations. The problem I have is that when I restart the calculation, it does not give me an error message, but it doesn't calculate the extra time steps I wanted. Has anyone encountered this problem before ?
Thanks !
Version 9.1
Restarting calculation
- setup.xml
- (7.26 KiB) Downloaded 5540 times
- compile.log
- (1.7 KiB) Downloaded 5527 times
- run_solver.log
- (17.65 KiB) Downloaded 5561 times
Re: Restarting calculation
How many additional time steps did you require ? Note that the number of time steps you specify in the code is by default an absolute number of time steps (same for the physical time), so if you have already reached that number, the restart simply checks values and rebuilds a postprocessing output).
