Output forces on surface
I have a simple model of a wing in a fluid domain. I want to output the overall resultant force and moment on the wing (which is a surface called 'wing' in the mesh). In OpenFOAM I can simply define a Reporting Function on the wing surface. I can't see a way in GUI to do this. Monitoring points seems to be just 1 point, I can't see a way to assign to a group.
Also my surface groups (Inlet, Outlet, wing, etc) don't seem to be preserved in the analysis, so when I open the results then I have a results file for the fluid domain and a result for Boundary case, but these both just contain a single block, I can't split out into my defined surfaces to get the force on just one surface (e.g. the wing), so I can't get the force that way either.
Re: Output forces on surface
In v7 or earlier versions, the simplest way is to create your surface in the mesh, then you can post-process the force using for example the "cs_user_extra_operations.f90" routine.
If you want the total x-force on the surface, for example, you simply have to write something as:
If you want to visualize the force in Paraview on every face of the surface, you can do the same and add a user-defined field (in the GUI) to store xfor(j,i_fac).
Hope this helps.
Daniele
! get the force vector
call field_get_val_v(iforbr, bfprp_for)
! get the surface where you want to post-process the force
call getfbr("surface_name", nlelt, lstelt)
xfor = 0.d0
do ilelt = 1, nlelt
ifac = lstelt(ilelt)
xfor = xfor + bfprp_for(1, ifac)
Hope this helps.
Daniele
Thank you for your reply
I'm using v8.0 beta.
I already have the surface defined in my mesh as "wing". Where should I put that test, I can't find a file called "cs_user_extra_operations.f90" in my case directory
When you say add user defined fields in the GUI, do you mean something like in the attached screenshots?
It is a user routine that you need to add in the SRC directory. I suggest you to have a look at the examples of such routines on the webiste or in the GUI.
Anyway, I have not used v8 yet, but I think they removed all fortran routines, so you will need to switch to C. The procedure remains the same, but I don't know exactly the variable name for the force in C, I am sorry...
You should be able to find it in the documentation online I guess.
Daniele
Daniele
In addition to this, using the GUI, you can generate postprocessing sub-meshes matching your surface groups, and associate them to the same or separate writers (don not forget that step). This allows you to visualize/sum/plot the results on these filtered groups.
Thank you Yvan, I'm trying to do it using the GUI. My face of interest is called 'wing' so I have set it up as shown in the screenshot below. However this gives me the error:
How should I express the selection criteria to just include the boundary face called wing?
Error parsing expression:
[wing]
Expected operator instead of operand.
Ah, so it looks like just having wing without the square brackets works.....
No, that still doesn't seem to be working, there doesn't seem to be any data when I open RESULTS_WING.case in Paraview.
Could you post at least the log files mentioned in the forum usage recommendations ?
Sorry so the details are:
version: 8.0-beta-09cdc7d58
Setup, complie and run_solver logs attached
- setup.log
- (27.63 KiB) Downloaded 1069 times
- compile.log
- (2.55 KiB) Downloaded 1058 times
- run_solver.log
- (560.63 KiB) Downloaded 1051 times
