Problem using cgns format mesh file from STAR CCM+ on CS 7.0
ximeng
Post by ximeng »
Dear Sir/Madam,
Hope you are well and sorry for bothering you.
I failed to import the .cgns mesh file from STAR CCM+ 2019.3.1 to code_saturne 7.0.1 with CGNS 4.3.0 at the preprocess stage in ARCHER2. The errors are shown as:
"code_saturne run --initialize --param setup.xml --nprocs 128
code_saturne
Version: 7.0.1
Path: /mnt/lustre/a2fs-work1/work/y07/shared/apps/core/code_saturne/7.0.1-gcc11
Result directory:
/mnt/lustre/a2fs-work1/work/e01/e01/w25036xk/code_saturne_ueharablocks/blocksall/testblocksall/revisedBetaEDF_LES/RESU/20230808-2245
Copying base setup data
Compiling and linking user-defined functions
Preparing calculation data
Parallel code_saturne on 128 processes.
Preprocessing calculation
Error in preprocessing stage.
But the preprocessor.log shows nothing (blank). My case is about the square computational domain including lots simplified building cubes. The mesh is trimmed mesh generated by STAR CCM+ with 0.002m first layer height. The meshes with 0.004m and 0.0025m first layer height run well, while it failed when with 0.002m/0.0022m first layer height. And I also tried mesh with uniform 0.01m base size and uniform 0.005m at lower part, and got the same error. I tried cgnsupdate but didn't work.
Any suggestions would be very appreciated!
Ximeng
Re: Problem using cgns format mesh file from STAR CCM+ on CS 7.0
Does the preprocessor work for this install using other file formats ? If the log is empty, I suspect an installation or execution environment/modules issue such that it does not start correctly.
Otherwise, you might have additional messages in the batch output and error logs (I guess you are using a batch system on Archer2).
ximeng
Post by ximeng »
Thanks for your reply!
For the first question, the preprocessor works for the .cgns format mesh file with 0.004/0.0025m first layer height from the STAR CCM+ 2019.3.1. And I also tried .ccm format but it seems that code_saturne on Archer2 doesn't support this format. The encountered error is as follows:
CGNS 4.3.0 file format support
Reading of compressed files ('.gz') with Zlib 1.2.11
ecs_pre.c:486: Fatal error.
File format "STAR-CCM+" support not available in this
installation (file "/mnt/lustre/a2fs-work1/work/e01/e01/w25036xk/code_saturne_ueharablocks/blocksall/testblocksall/MESH/blocks_Uehara2000_benchmark_noprism_0.002m.ccm").
Call stack
1: 0x40cc9f <ecs_pre__type_format+0x3bf> (cs_preprocess)
2: 0x4080e3 <ecs_cmd__lit_arg+0x2c3> (cs_preprocess)
3: 0x406079 <main+0x39> (cs_preprocess)
4: 0x7f3b522a729d <__libc_start_main+0xef> (libc.so.6)
5: 0x4067ba <_start+0x2a> (cs_preprocess)
Besides, If it is due to the installation or execution environment, why the mesh with larger first layer height could be successfully preprocessed. I just changed the first layer height value in the automated mesh setting in STAR CCM+. The current issue is that it operates intermittently, succeeding on occasions but failing for certain other meshes, and it does not provide any errors that would allow me to determine the cause.
For your reference, I have attached the preprocessor.log file obtained from the successful preprocessing of a mesh with a first-layer height of 0.004m.(preprocessor_0.004mfirstLayerHeight_CGNS.log)
In addition, I also tried to export the .cgns format mesh file through STAR CCM+ 2022.1 and it showed messages in preprocessor.log (showed nothing when use STAR CCM+ 2019.3.1) as attached.(preprocessor_exportCGNSfromSTAR2022.log)
Ximeng
(7.26 KiB) Downloaded 679 times
(3.96 KiB) Downloaded 672 times
Your issue is probably the same as this one viewtopic.php?f=2&t=3132.
Your file that can be read is in CGNS 3.2 format, the one that fails is in 3.4, and the way CGNS handled forward and backwards compatibility moving from version 3.3 to 3.4.0 back to 3.4.1 was a massive failure.
So you can also try using the cgnsview too to change the format indication from 3.4 to 3.3, and see if that works.
ximeng
Post by ximeng »
Hi, Yvan,
Thanks.
I installed cgnsview successfully just now. It showed that my file info is CGNS 3.2.1. But I couldn't find the option to change the CGNS version, and not much introduction in the CGNS website. Also it always frozen in GUI. Does it just need to save as another file (but no place to define the output version), or output using user defined file? Could you give me some suggestion about this? Sorry for the bothering of this simple question. My mesh file is uploaded for reference: https://www.dropbox.com/scl/fi/3yd32fic ... tsgs3&dl=0
Besides, I also tried to use .ccm format mesh file but got the same error as attached.
Ximeng
preprocessor_.ccm_meshformat.log
(1.85 KiB) Downloaded 663 times
Helllo,
Could you test with a smaller file or provide a smaller test file ? This is good practice in general, unless you can reproduce an issue only on a specific, large case. I can only access Dropbox from my home PC (not connected to a cluster), so 17 Gb is too large by a wide margin...
ximeng
Post by ximeng »
Thanks for your help.
I generated a mesh for a smaller computational domain. There is something showing in the preprocessor.log this time. The mesh file and the preprocessor.log are attached.
Besides, I am still not clear about how to change the .cgns version in cgnsview.
Ximeng
preprocessor_SmallerFile_onlyCityBlocks.log
(2.18 KiB) Downloaded 666 times
blocks_Uehara2000_noprism_notrippingfence.rar
(7.98 MiB) Downloaded 693 times
There seem to be an issue with the archive, as I cannot open it even ith CGNS or HDF5 checking tools.
in addition, a 278 Mb CGNS file for an 8 Mb Rar file does not seem to be a realistic compression ratio.
So your file is corrupt.
But the error message in the log says it all. Please read it.
If your CGNS library does not support HDF5 files, use hdf2adf on another machine do do so.
This is not a code _saturne issue.
ximeng
Post by ximeng »
Thanks! I have some updates about the previous large mesh in the Dropbox link (actually, all the meshes are generated by the same star ccm+ version and exported by the same way, but got different preprocessor.log results on code_saturne)
I successfully changed the file to version 3.3.0 and 4.3.0 on cgnsview, and inputted them to code_saturne, but unfortunately the same error was encountered. (The original mesh file version shown in the cgnsview is 3.2.1)
“Error running the preprocessor.
Error in preprocessing stage.”
But still nothing is shown in preprocessor.log with Version 3.3.0. The preprocessor.log with version 4.3.0 shown errors like (which is attached):
"Number of vertices : 65670835
SIGSEGV signal (access to forbidden memory area) intercepted !
Call stack
1: 0x40ed53 <> (cs_preprocess)
2: 0x412dc8 <ecs_pre_cgns__lit_maillage+0x1e78> (cs_preprocess)
3: 0x40cf1b <ecs_pre__lit_maillage+0xeb> (cs_preprocess)
4: 0x4060c7 <main+0x87> (cs_preprocess)
5: 0x7f769ef3b29d <__libc_start_main+0xef> (libc.so.6)
6: 0x4067ba <_start+0x2a> (cs_preprocess)
End of stack”
Ximeng
preprocessor_CGNSversion4.3.log
(3.58 KiB) Downloaded 640 times
Could you simply post a small .cgns mesh generated by STAR-CCM+ 2019, without modifying it, so that !i can try to reproduce the error on my side ?
Also, given the error message in one of your previous posts, the problem is probably related to ADF or HFD5 variant support of CGNS. I recommend updating to at least code_saturne bug-fix release 7.0.3 (but 7.0.6 is better) to have automatic switch between the 2 variants.
