Hi all,
I'm trying to use a mesh generated in Star-CCM+ in Code_Saturne 8.0, but I'm getting errors at the preprocessing stage:
- In the case of exporting it with the .cgns format (which, according to code_saturne's documentation, is recommended over .ccm), I get the error shown in cgns_preprocessor.log.
- In the case of exporting it with the .ccm format, I get the error shown in ccm_preprocessor.log.
In this regard, I am using:
Code_Saturne 8.0 with CGNS 3.3.1
Star-CCM+14.04.011-R8 with CGNS 3.2.1a
(I cannot modify the installation of Star-CCM+, if required, because it is in a cluster to which I have limited access).
I think the best thing would be to make it work with .cgns.
Thank you in advance.
Problem using cgns format file on CS 8.0
- ccm_preprocessor.log
- (2.17 KiB) Downloaded 686 times
- cgns_preprocessor.log
- (2.83 KiB) Downloaded 683 times
Re: Problem using cgns format file on CS 8.0
Hard to say if this is a version of a CGNS file which does not quite folllow the standard or an installation issue.
Could you post a small test CGNS file generated with the same software ?
Did you try various export sub-options ?
Sorry for the delay. I generated several files just in case, using different options to export. I see that in another post a problem arose that can be linked. I understand that, in my case, the version of the library is 3.21. I also attach the options that appear to me to export from the software.
- meshtest3_expl.cgns
- (1.13 MiB) Downloaded 656 times
- meshtest3.cgns
- (1.13 MiB) Downloaded 674 times
The meshes read fine on my side. Looking at your error message, I suspect that your CGNS library install does not include HDF5 support (and the files are indeed HDF5-based, not ADF-based).
In doubt if the CGNS "hdf2adf" utility is available, yoy can convert the file and try reading it...
I don't know if it's determinative, but running the ldd command I don't see any trace of any link to any hdf5 library in the cluster:
[finzeo@seshat gnu7.1]$ ldd libcgns.so
linux-vdso.so.1 => (0x00007ffe7e5ee000)
libc.so.6 => /lib64/libc.so.6 (0x00007f82286a3000)
/lib64/ld-linux-x86-64.so.2 (0x00007f8228d30000)
It may depend on several factors, but on my install, I do see libhdf5.so when I run ldd on libcgns.so.
If you are not the person installing CGNS and the hdf2adf utility is not available on that cluster, you might be able to run it on a workstation. If you handle your own installs, I recommend adding HDF5 support to CGNS as it make things more "transparent".
Thank you Yvan!
