Energy Equation Subroutines and adding terms in it
hyder4
Post by hyder4 »
Dear Developers,
I just started PhD and my work is mostly on DNS. I want to add few terms in the energy equation.
Is it possible if you can point out what subroutine(s) the software solves the energy equation? and is there a way I can add terms in it?
Kind regards,
Hyder.
hyder4
Re: Energy Equation Subroutines and adding terms in it
Post by hyder4 »
Dear Developer,
I was wondering if there is any update on this?
Kind regards,
Hyder.
Which "energy equation" are you referring to exactly relative to the formulation and algorithm used in code_saturne ? Turbulent kinetic energy (not in DNS), thermal internal or total energy (for compressible flowà, ... ?
Did you check user examples in the documentation ?
hyder4
Post by hyder4 »
Sorry I mean is this energy equation.
(3.18 KiB) Not downloaded yet
or this
(5.79 KiB) Not downloaded yet
Hyder.
Gao, Pitz, Chew_2020_International Journal of Heat and Mass Transfer_Numerical investigation of buoyancy-induced flow in a sealed rap(2) (1).pdf
(1.56 MiB) Downloaded 607 times
So it seems that what you are interested in is the heat equation. What sort of terms do you need to add ? If it is source terms, that is easy, and there are many user-defined examples in the code. Some cases may even be handled in the GUI.
I also recommend starting with a very simple mesh and case so as to be able to experiment with a fast turnaround time.
hyder4
Post by hyder4 »
The terms I want to add depends on what heat equation the code_saturne is solving at the moment. may I ask if its solving equation 1
or equation 2
One of my senior is also using code saturne. he believes code_saturne solves equation 1.
Hyder
The info on the equations solved is given in the first 20 pages of the theory manual.
hyder4
Post by hyder4 »
Just looked at it Thank you. I am also curious to know in what subroutines they are being solved. is there a way I can know that as well?
Best,
Hyder.
Depending on the code version (and progress on migration from Fortran to C), the exact files can vary, but you can start by looking at the "scalai" function, which contains the loop on scalars.
