I am now to Idris cluster
When I am trying to run code_saturne 7.2 in idris cluster. I am getting the following error message
"./cs_solver: error while loading shared libraries: libirng.so: cannot open shared object file: No such file or directory
solver script exited with status 127."
The same setup file works fine for me in Curta cluster.
Any idea to resolve this error ?
Thanks in advance
With Thanks and Regards
Sofen
Error using code Saturne 7.2 in idris cluster
sofenkumarjena
Re: Error using code Saturne 7.2 in idris cluster
This seems to be an installation issue. Can you post in the corresponding part of the forum ? With the recommended info ?
sofenkumarjena
Getting the following error message. No idea what exactly this error for
Loading code-saturne/7.2
Loading requirement: intel-compilers/19.1.3 intel-mpi/2019.9 intel-mkl/2020.4
hdf5/1.12.0-mpi scotch/6.0.10-mpi petsc/3.17.4-mpi
code_saturne
Version: 7.2.0
Copying base setup data
Compiling and linking user-defined functions
Preparing calculation data
Parallel code_saturne on 1600 processes.
Preprocessing calculation
Starting calculation
"slurm-1069758.out" 139L, 11168C 49,1 Top
code_saturne
Version: 7.2.0
Did you read my previous response ?
This is not the only information I need, and this is not in the correct section....
