CGNS Mesh reading error in Curta Cluster
Hi I have a Mesh in .CGNS format, which works fine in the local machine. But reading the mesh in Curta cluster gives following error.
Any help/suggestions in this regard is appreciated.
With Regards
Sofen
Reading mesh from file in CGNS format
Mesh file: /gpfs/home/skjena/2D_RANS_CAVITY/unstructured_mesh/unstructuredkw_cluster/MESH/New_cavity_mesh_CELL_HD.cgns
/gpfs/softs/contrib/apps/code_saturne/5.3.0/sources/preprocessor/pre-post/ecs_pre_cgns.c:255: Fatal error.
CGNS error:
CGNS file -1322924040 is not open
This may be due to a CGNS library supporting only ADF (legacy)
or HDF5 (future default) and the file not matching. In this case,
running the adf2hdf of hdf2adf converters may solve the issue.
With Regards
Sofen
CGNS error:
Re: CGNS Mesh reading error in Curta Cluster
Which version of the code are you using ?
It is code Saturne 5.3.0 release. The mesh works fine in my local machine with same version, which has CGNS 4.2.0.
With Thanks and Regards
Sofen
Sofen
It is probably an hdf5/adf support issue.
Also, supported versions of code_saturne can automatically select hdf5 or adf.
For older versions, try the cgns adf to hdf5 conversion tools.
Beat regards,
Beat regards,
I have native mesh in both CGNS and ADF format. Both Format gives error in curta cluster.
in ADF version it is giving error message that, the file being used is more recent that the CGNS library used.
Which versions of CGNS is used on the cluster, according to the code_saturne preprocessor log ?
Please find the preprocessor.log file output. Kindly help me.
/gpfs/softs/contrib/apps/code_saturne/5.3.0/curta/release/libexec/code_saturne/cs_preprocess
--log --out mesh_input
/gpfs/home/skjena/2D_RANS_CAVITY/unstructuredkw_cluster/MESH/New_Annular_Mesh_Cell_HD.cgns
| Code_Saturne Preprocessor |
code_saturne version 5.3.0 (built mer. 24 avril 2019 13:37:18 CEST)
CGNS 3.1.3 file format support
MED 3.1.0 (HDF5 1.8.14) file format support
Reading of compressed files ('.gz') with Zlib 1.2.7
Case configuration
Date : lun. 27 juin 2022 23:20:22 CEST
System : Linux 3.10.0-1160.el7.x86_64
Machine : login02
Processor : Intel(R) Xeon(R) Gold 6130 CPU @ 2.10GHz
Memory : 197259132
User : skjena (Sofen Kumar Jena)
Directory : /gpfs/home/skjena/2D_RANS_CAVITY/unstructuredkw_cluster/RESU/20220627-2320
Case name : preprocess
Mesh file : /gpfs/home/skjena/2D_RANS_CAVITY/unstructuredkw_cluster/MESH/New_Annular_Mesh_Cell_HD.cgns
Mesh file: /gpfs/home/skjena/2D_RANS_CAVITY/unstructuredkw_cluster/MESH/New_Annular_Mesh_Cell_HD.cgns
CGNS error:
CGNS file -2124335112 is not open
Case configuration
Machine : login02
Memory : 197259132
CGNS error:
The version of CGNS with which code_saturne is installed on the cluster is also older...
This is mostly an installation issue, though only up-to date supported versions of code_saturne (v6.0, v7.0, v7.1) automatically detect ADF/HDF5 versions, avoiding the need for conversion. v5.3 has been retired since September 2019, so upgrading to v7.0 is highly recommended also.
The version 5.3 works fine for me in the local system. Here is the preprocessor log. I guess, up-gradation of CGNS is required. Kindly help, in trouble
/home/skjena/Code_Saturne/5.3.4/code_saturne-5.3.4/arch/Linux_x86_64/libexec/code_saturne/cs_preprocess
/media/skjena/251cfb2d-1a0c-4ca3-bb02-d0b32a0298fc/skjena/Code_Satrune_Results/unstructured_mesh/unstructured_kw/MESH/New_cavity_mesh_CELL_HD.cgns
code_saturne version 5.3.4 (built mer. 19 janv. 2022 14:09:04)
CGNS 3.3.1 file format support
MED 4.0.0 (HDF5 1.10.4) file format support
Reading of compressed files ('.gz') with Zlib 1.2.11
Case configuration
Date : sam. 18 juin 2022 15:27:59
System : Linux 5.13.0-51-generic
Machine : skjena-Precision-3551
Processor : Intel(R) Core(TM) i7-10850H CPU @ 2.70GHz
Memory : 15979512
Directory : /media/skjena/251cfb2d-1a0c-4ca3-bb02-d0b32a0298fc/skjena/Code_Satrune_Results/unstructured_mesh/unstructured_kw/RESU/20220618-1527
Mesh file : /media/skjena/251cfb2d-1a0c-4ca3-bb02-d0b32a0298fc/skjena/Code_Satrune_Results/unstructured_mesh/unstructured_kw/MESH/New_cavity_mesh_CELL_HD.cgns
Mesh file: /media/skjena/251cfb2d-1a0c-4ca3-bb02-d0b32a0298fc/skjena/Code_Satrune_Results/unstructured_mesh/unstructured_kw/MESH/New_cavity_mesh_CELL_HD.cgns
CGNS version : 3.3
Base name : Base
Physical dimension : 3
Cell dimension : 3
Number of zones : 1
Zone 1: "Zone"; type "Unstructured"
117786 vertices; 175735 cells
(cartesian coordinates, "RealDouble" precision, unit "Null")
Section 1: "natural_convection_cavity-01";
(indices 1 to 5378, type "MIXED")
Section 2: "natural_convection_cavity-02";
(indices 5379 to 13220, type "MIXED")
Section 3: "natural_convection_cavity-03";
(indices 13221 to 21172, type "MIXED")
Section 4: "natural_convection_cavity-04";
(indices 21173 to 29110, type "MIXED")
Section 5: "natural_convection_cavity-05";
(indices 29111 to 36959, type "MIXED")
Section 6: "natural_convection_cavity-06";
(indices 36960 to 42339, type "MIXED")
Section 7: "natural_convection_cavity-07";
(indices 42340 to 57901, type "MIXED")
Section 8: "bc_inner_bottom-natural_conv-24";
(indices 57902 to 57926, type "MIXED")
Section 9: "bc_inner_bottom-natural_conv-25";
(indices 57927 to 58054, type "MIXED")
Section 10: "bc_outer_top-natural_convect-26";
(indices 58055 to 58129, type "MIXED")
Section 11: "bc_outer_top-natural_convect-27";
(indices 58130 to 58273, type "MIXED")
Section 12: "bc_outer_bottom-natural_conv-28";
(indices 58274 to 58348, type "MIXED")
Section 13: "bc_outer_bottom-natural_conv-29";
(indices 58349 to 58492, type "MIXED")
Section 14: "symmetric_1-natural_convecti-30";
(indices 58493 to 63870, type "MIXED")
Section 15: "symmetric_1-natural_convecti-31";
(indices 63871 to 71712, type "MIXED")
Section 16: "symmetric_1-natural_convecti-32";
(indices 71713 to 79664, type "MIXED")
Section 17: "symmetric_1-natural_convecti-33";
(indices 79665 to 87602, type "MIXED")
Section 18: "symmetric_1-natural_convecti-34";
(indices 87603 to 95451, type "MIXED")
Section 19: "symmetric_1-natural_convecti-35";
(indices 95452 to 100831, type "MIXED")
Section 20: "symmetric_1-natural_convecti-36";
(indices 100832 to 116393, type "MIXED")
Section 21: "symmetric_2-natural_convecti-37";
(indices 116394 to 121771, type "MIXED")
Section 22: "symmetric_2-natural_convecti-38";
(indices 121772 to 129613, type "MIXED")
Section 23: "symmetric_2-natural_convecti-39";
(indices 129614 to 137565, type "MIXED")
Section 24: "symmetric_2-natural_convecti-40";
(indices 137566 to 145503, type "MIXED")
Section 25: "symmetric_2-natural_convecti-41";
(indices 145504 to 153352, type "MIXED")
Section 26: "symmetric_2-natural_convecti-42";
(indices 153353 to 158732, type "MIXED")
Section 27: "symmetric_2-natural_convecti-43";
(indices 158733 to 174294, type "MIXED")
Section 28: "bc_hot-natural_convection_ca-44";
(indices 174295 to 174295, type "MIXED")
Section 29: "bc_hot-natural_convection_ca-45";
(indices 174296 to 174405, type "MIXED")
Section 30: "bc_hot-natural_convection_ca-46";
(indices 174406 to 174516, type "MIXED")
Section 31: "bc_hot-natural_convection_ca-47";
(indices 174517 to 174627, type "MIXED")
Section 32: "bc_hot-natural_convection_ca-48";
(indices 174628 to 174737, type "MIXED")
Section 33: "bc_hot-natural_convection_ca-49";
(indices 174738 to 174738, type "MIXED")
Section 34: "bc_inner_top-natural_convect-50";
(indices 174739 to 174763, type "MIXED")
Section 35: "bc_inner_top-natural_convect-51";
(indices 174764 to 174891, type "MIXED")
Section 36: "bc_inner_right";
(indices 174892 to 175024, type "MIXED")
Section 37: "bc_cold_1-natural_convection-53";
(indices 175025 to 175075, type "MIXED")
Section 38: "bc_cold_1-natural_convection-54";
(indices 175076 to 175185, type "MIXED")
Section 39: "bc_cold_1-natural_convection-55";
(indices 175186 to 175296, type "MIXED")
Section 40: "bc_cold_1-natural_convection-56";
(indices 175297 to 175407, type "MIXED")
Section 41: "bc_cold_1-natural_convection-57";
(indices 175408 to 175517, type "MIXED")
Section 42: "bc_cold_1-natural_convection-58";
(indices 175518 to 175568, type "MIXED")
Section 43: "bc_cold_2";
(indices 175569 to 175735, type "MIXED")
CGNS boundary condition information:
Zone 1
BC 1: "bc_cold_2-wall" ("BCWall" on "FaceCenter")
BC 2: "bc_cold_1-natural_convection-53" ("BCWall" on "FaceCenter")
BC 3: "bc_inner_right-wall" ("BCWall" on "FaceCenter")
BC 4: "bc_inner_top-natural_convect-51" ("BCWall" on "FaceCenter")
BC 5: "bc_cold_1-natural_convection-58" ("BCWall" on "FaceCenter")
BC 6: "symmetric_1-natural_convecti-30" ("BCSymmetryPlane" on "FaceCenter")
BC 7: "symmetric_1-natural_convecti-31" ("BCSymmetryPlane" on "FaceCenter")
BC 8: "symmetric_1-natural_convecti-32" ("BCSymmetryPlane" on "FaceCenter")
BC 9: "symmetric_1-natural_convecti-33" ("BCSymmetryPlane" on "FaceCenter")
BC 10: "symmetric_1-natural_convecti-34" ("BCSymmetryPlane" on "FaceCenter")
BC 11: "bc_inner_bottom-natural_conv-24" ("BCWall" on "FaceCenter")
BC 12: "bc_inner_bottom-natural_conv-25" ("BCWall" on "FaceCenter")
BC 13: "bc_outer_top-natural_convect-26" ("BCWall" on "FaceCenter")
BC 14: "bc_outer_top-natural_convect-27" ("BCWall" on "FaceCenter")
BC 15: "bc_outer_bottom-natural_conv-28" ("BCWall" on "FaceCenter")
BC 16: "bc_outer_bottom-natural_conv-29" ("BCWall" on "FaceCenter")
BC 17: "symmetric_1-natural_convecti-35" ("BCSymmetryPlane" on "FaceCenter")
BC 18: "symmetric_1-natural_convecti-36" ("BCSymmetryPlane" on "FaceCenter")
BC 19: "symmetric_2-natural_convecti-37" ("BCSymmetryPlane" on "FaceCenter")
BC 20: "bc_hot-natural_convection_ca-45" ("BCWall" on "FaceCenter")
BC 21: "bc_hot-natural_convection_ca-47" ("BCWall" on "FaceCenter")
BC 22: "symmetric_2-natural_convecti-38" ("BCSymmetryPlane" on "FaceCenter")
BC 23: "bc_hot-natural_convection_ca-46" ("BCWall" on "FaceCenter")
BC 24: "bc_hot-natural_convection_ca-44" ("BCWall" on "FaceCenter")
BC 25: "symmetric_2-natural_convecti-39" ("BCSymmetryPlane" on "FaceCenter")
BC 26: "bc_hot-natural_convection_ca-48" ("BCWall" on "FaceCenter")
BC 27: "bc_hot-natural_convection_ca-49" ("BCWall" on "FaceCenter")
BC 28: "symmetric_2-natural_convecti-40" ("BCSymmetryPlane" on "FaceCenter")
BC 29: "symmetric_2-natural_convecti-41" ("BCSymmetryPlane" on "FaceCenter")
BC 30: "symmetric_2-natural_convecti-42" ("BCSymmetryPlane" on "FaceCenter")
BC 31: "symmetric_2-natural_convecti-43" ("BCSymmetryPlane" on "FaceCenter")
BC 32: "bc_cold_1-natural_convection-54" ("BCWall" on "FaceCenter")
BC 33: "bc_cold_1-natural_convection-55" ("BCWall" on "FaceCenter")
BC 34: "bc_cold_1-natural_convection-56" ("BCWall" on "FaceCenter")
BC 35: "bc_cold_1-natural_convection-57" ("BCWall" on "FaceCenter")
BC 36: "bc_inner_top-natural_convect-50" ("BCWall" on "FaceCenter")
Number of vertices : 117786
Number of faces : 117834
Number of cells : 57901
Group "bc_cold_2-wall"
Number of faces : 167
Group "bc_cold_1-natural_convection-53"
Number of faces : 51
Group "bc_inner_right-wall"
Number of faces : 133
Group "bc_inner_top-natural_convect-51"
Number of faces : 128
Group "bc_cold_1-natural_convection-58"
Group "symmetric_1-natural_convecti-30"
Number of faces : 5378
Group "symmetric_1-natural_convecti-31"
Number of faces : 7842
Group "symmetric_1-natural_convecti-32"
Number of faces : 7952
Group "symmetric_1-natural_convecti-33"
Number of faces : 7938
Group "symmetric_1-natural_convecti-34"
Number of faces : 7849
Group "bc_inner_bottom-natural_conv-24"
Number of faces : 25
Group "bc_inner_bottom-natural_conv-25"
Group "bc_outer_top-natural_convect-26"
Number of faces : 75
Group "bc_outer_top-natural_convect-27"
Number of faces : 144
Group "bc_outer_bottom-natural_conv-28"
Group "bc_outer_bottom-natural_conv-29"
Group "symmetric_1-natural_convecti-35"
Number of faces : 5380
Group "symmetric_1-natural_convecti-36"
Number of faces : 15562
Group "symmetric_2-natural_convecti-37"
Group "bc_hot-natural_convection_ca-45"
Number of faces : 110
Group "bc_hot-natural_convection_ca-47"
Number of faces : 111
Group "symmetric_2-natural_convecti-38"
Group "bc_hot-natural_convection_ca-46"
Group "bc_hot-natural_convection_ca-44"
Number of faces : 1
Group "symmetric_2-natural_convecti-39"
Group "bc_hot-natural_convection_ca-48"
Group "bc_hot-natural_convection_ca-49"
Number of faces : 1
Group "symmetric_2-natural_convecti-40"
Group "symmetric_2-natural_convecti-41"
Group "symmetric_2-natural_convecti-42"
Group "symmetric_2-natural_convecti-43"
Group "bc_cold_1-natural_convection-54"
Group "bc_cold_1-natural_convection-55"
Group "bc_cold_1-natural_convection-56"
Group "bc_cold_1-natural_convection-57"
Group "bc_inner_top-natural_convect-50"
Wall-clock time: 0.080790 s; CPU time: 0.080768 s
Done reading mesh
Theoretical mesh size: 9.369 Mb
Theoretical current memory: 12.066 Mb
Theoretical peak memory: 21.880 Mb
Total memory used: 47.855 Mb
Domain coordinate extents:
[-5.00000e-01, -5.00000e-01, -5.00000e-04]
[ 5.00000e-01, 5.00000e-01, 5.00000e-04]
Number of elements tria3 : 96
Number of elements quad4 : 117738
Number of elements penta6 : 48
Number of elements hexa8 : 57853
Defining families
Element orientation check.
End of conversion to descending connectivity
Theoretical mesh size: 12.853 Mb
Theoretical current memory: 15.550 Mb
Theoretical peak memory: 35.530 Mb
Total memory used: 67.316 Mb
Main mesh properties
Number of cells: 57901
Number of internal faces: 114762
Number of boundary faces: 117834
Number of vertices: 117786
Definition of face and cell families
Family 1
Number of boundary faces : 51
Family 2
Number of boundary faces : 110
Family 3
Number of boundary faces : 111
Family 4
Family 5
Family 6
Family 7
Number of boundary faces : 167
Family 8
Family 9
Family 10
Family 11
Family 12
Family 13
Family 14
Number of boundary faces : 25
Family 15
Number of boundary faces : 128
Family 16
Number of boundary faces : 133
Family 17
Family 18
Family 19
Number of boundary faces : 75
Family 20
Number of boundary faces : 144
Family 21
Family 22
Family 23
Number of boundary faces : 5378
Family 24
Number of boundary faces : 7842
Family 25
Number of boundary faces : 7952
Family 26
Number of boundary faces : 7938
Family 27
Number of boundary faces : 7849
Family 28
Number of boundary faces : 5380
Family 29
Number of boundary faces : 15562
Family 30
Family 31
Family 32
Family 33
Family 34
Family 35
Family 36
Family 36
Default family
(no group)
Number of internal faces : 114762
Write output for Kernel
Opening file: mesh_input
Wrote: "start_block:dimensions"
Wrote: "n_cells" ; Type: "u8"; Size: 1
Wrote: "n_faces" ; Type: "u8"; Size: 1
Wrote: "n_vertices" ; Type: "u8"; Size: 1
Wrote: "face_vertices_size" ; Type: "u8"; Size: 1
Wrote: "n_group_classes" ; Type: "i8"; Size: 1
Wrote: "n_group_class_props_max" ; Type: "i8"; Size: 1
Wrote: "n_groups" ; Type: "u8"; Size: 1
Wrote: "group_name_index" ; Type: "i8"; Size: 37
Wrote: "group_name" ; Type: "c "; Size: 1123
Wrote: "group_class_properties" ; Type: "i8"; Size: 37
Wrote: "end_block:dimensions"
Wrote: "start_block:data"
Wrote: "face_cells" ; Type: "i8"; Size: 465192
Wrote: "cell_group_class_id" ; Type: "i8"; Size: 57901
Wrote: "face_group_class_id" ; Type: "i8"; Size: 232596
Wrote: "face_vertices_index" ; Type: "u8"; Size: 232597
Wrote: "face_vertices" ; Type: "i8"; Size: 930288
Wrote: "vertex_coords" ; Type: "r8"; Size: 353358
Wrote: "end_block:data"
Wrote: "EOF"
Closing file: mesh_input
Time and memory summary
User CPU time (sec) : 0.18
System CPU time (sec) : 0.03
Total time (sec) : 0.21
Total CPU time / Total time : 1.01
Memory use summary:
Theoretical instrumented dynamic memory: 35.530 Mb
| Preprocessor finish |
Case configuration
Memory : 15979512
CGNS version : 3.3
Base name : Base
Cell dimension : 3
Number of zones : 1
Zone 1
Number of faces : 1
Number of faces : 1
Done reading mesh
Defining families
Family 1
Family 2
Family 3
Family 4
Family 5
Family 6
Family 7
Family 8
Family 9
Family 10
Family 11
Family 12
Family 13
Family 14
Family 15
Family 16
Family 17
Family 18
Family 19
Family 20
Family 21
Family 22
Family 23
Family 24
Family 25
Family 26
Family 27
Family 28
Family 29
Family 30
Family 31
Family 32
Family 33
Family 34
Family 35
Family 36
Family 36
Default family
(no group)
Wrote: "EOF"
Memory use summary:
I repeat:
- Code_saturne 5.3 is not supported anymore. I can answer some questions out of memory, but I will not spend significant amounts of time supporting issues with that version, whatever the reason (I already have my hands full with current versions).
- The main issue here is due to the CGNS version and/or installation on your cluster. That is something you have to handle/upgrade on your side.
And finally, you could work around this generating the mesh_input by preprocessing on your workstation and then use that directly on the cluster, unless the mesh is too large.
I repeat:
