Compute boundary conditions with data from other calculation
Roxan
Post by Roxan »
Dear all,
We have 2 different mesh with a common surface, see as outlet for one mesh and inlet for the other one. After a first calculation on the first mesh is it possible to use outlet data to compute inlet condition for a new calculation on the other mesh?
The objective being to separate space in two different mesh and then only made a single calculation on the first mesh part.
Roxan
Re: Compute boundary conditions with data from other calculation
Yes, this should be possible. The easiest solution is to use MEDCoupling (assuming you built code_saturne with MEDCoupling support). See example here: https://www.code-saturne.org/documentat ... er_2d.html
Without this, you could use the build-in PLE library and checkpoint meshes, but this would involve significantly more programming.
Roxan
Post by Roxan »
Thank you very much for your reply. Unfortunately my version of code-saturn is not installed with MEDcoupling but we are on it.
Roxan
