Divergence for simple geometry room
Re: Divergence for simple geometry room
Sorry, I did not have the time to test the case yet. I'll let you know as soon as I run it.
Tsubasa
Post by Tsubasa »
Ok, Thanks.
Even in steady simulation, divergence problem happned.
Hamada
Changing the outlet to "imposed pressure outlet" alone was not sufficient, but switching to least-squares gradient reconstruction with full extended neighborhood, I can run 500 iterations just fine (tested with v7.0).
Tsubasa
Post by Tsubasa »
Thank you for the test.
I am grad to hear that steady simulation can be done by steady simulation.
Also how about unsteady case?
Do you think it can be done with Ver.6?
Finally I want to do pressure-driven flow by SRC code, but now the simulation has a divergenec problem with Ver.6.
Tsubasa
I actually ran the test for an unsteady flow (as your setup.xml was set for unsteady, constant time step).
This should probably also work in v6.0, though I recommend upgrading to v7.0.
Pressure driven flow should work, but may be a bit more sensitive. Increasing the pressure difference progressively (using a ramp type function) rather than all at once might help.
Tsubasa
Post by Tsubasa »
Thanks a lot.
At first, I will build Ver.7 and do the test with it.
Tsubasa
Tsubasa
Post by Tsubasa »
In the previou post, you said "least-squares gradient reconstruction with full extended neighborhood".
Is this same to "least squares method over extended cell neighborhood" in Ver.6?
Tsubasa
Yes, it is the same.
Tsubasa
Post by Tsubasa »
As you said, a simulation can be done by "least squares method over extended cell neighborhood" in Ver.6,
but the pressure difference flow simulation had a divergence problem.
In my case, pressure difference is just 0.6Pa. This is very small, but the result became divergent.
Tsubasa
Tsubasa
Post by Tsubasa »
Do you think Ver.7 is more stable for computation than Ver.6?
(Idealy, I want to conduct a pressure driven flow by steady simulation (not URANS).)
If you think so, I want to try it with Ver.7.
If it is possible, every problem can be solved, which is posted in another post.
Tsubasa
