I am trying to install Syrthes 4.3.5 on Ubuntu 18.04.5. It seems there is some problem with med (I give the path oh med installed by CS6.06), but I cannot find where.
Attached are setup file, and error log.
Do you have any idea.
Lamia
CS/Syrthes installation
- setup.ini
- (4.13 KiB) Downloaded 8284 times
- ERREUR.log
- (1.73 KiB) Downloaded 8434 times
Re: CS/Syrthes installation
Could you output the result of :
Best regards,ls /home/abbas/Code_Saturne_b/6.0.6/med-4.0.0/arch/Linux_x86_64/
The output is :
Lamia
Thank you~/Code_Saturne_b/6.0.6/med-4.0.0/arch/Linux_x86_64$ ls
bin include lib share
Lamia
That seems OK. Do you have a "med.h" file under "include" ? If so, I do not see what may be wrong, unless some "include path" argument is not passed by the build scripts/Makefile (but since the build is not verbose, it is hard to know).
What type of system are you running on ?
Hi Yvan
Yes there is a med.h file under the include folder
Lamia
Ubuntu 18..04.5What type of system are you running on ?
Lamia
Do you confirm this is the version of Syrthes available on this web site ? I am not sure how to make the compilation more verbose.
One workaround may be to define the general C_INCLUDE_PATH variable
(export C_INCLUDE_PATH=/home/abbas/Code_Saturne_b/6.0.6/med-4.0.0/arch/Linux_x86_64/include).
I tried again after restarting my computer(without defining the variable C_INCLUDE_PATH variable). I no longer have a med error. But the file ERROR.log still non-empty.
Do you think that is annoying?
Lamia
Yes it is.Do you confirm this is the version of Syrthes available on this web site ?
Lamia
- ERREUR.log
- (1.39 KiB) Downloaded 8337 times
I think that my problem is PyQt5 because when I try the command syrthes.gui, I have the following error
Lamia
however, I installed it with the command : pip install PyQt5, and it appears when I check with the command : pip list. Do you have an idea?ImportError: No module named PyQt5
Lamia
In which order did you install things ? Why did you use pip install instead of the standard Ubuntu packages ? That would be simpler and safer, if you have admin/sudo access on your machine. Otherwise, you need to make sure the correct environment (used by Pip) is also loaded for Syrthes. And as I am not too familiar with the Syrthes build system, you are probably on your own in this case, unless someone else here has worked around this type of issue.
If you can install the Ubuntu packages (same as those recommended for code_saturne on the GitHub wiki, plus PyQtcharts), I would try that instead.
I would like to make a return, maybe another person will face the same problem.
Everything was well installed, but the command python in my environment points to python2. So, I replace pyton by python3 in the file syrthes.gui.
Know I have some problem with syrthesconvert. I suspect the compiler is too recent.
Thank you very much for all
Lamia
Lamia
- ERREUR.log
- (1.39 KiB) Downloaded 8287 times
