Solution control, fluid properties
User avatar
jcharris
Post by jcharris »
When looking at the output files, is it normal that one cannot turn off the density and molecular_viscosity fields from the default writer?
For some test cases, in order to save space, I un-check the fluid properties from the "post-processing" list in the volume solution control, but the files are saved anyway.
If useful, I can create a small example.
Best,
Jeff
Re: Solution control, fluid properties
I'll try to reproduce this myself. On which version of the code does this happen ?
User avatar
jcharris
Post by jcharris »
The problem was noticed with VOF enabled in v6.0. I am able to replicate it with v6.2.0.
In some sense, perhaps it is logical to always save the fluid properties for VOF. But in this case, it is strange from a user interface point of view if the checkbox in the volume solution control panel does nothing.
