Ansys CGNS to Code_Saturne 6.1
Marsang
Post by Marsang »
I would like to know how you usually proceed to import CGNS mesh from Ansys Mesher to Code_Saturne 6.1.
I describe my problems and interrogations :
Context :
MESH CGNS 3.2 ADF from Ansys Mesher
Code_Saturne 6.1 (Code_Saturne GUI only !) on Ubuntu 20.04 LTS
Main proplem :
When I import mesh to Code_Saturne and I run case, case running console writes :
Preparing calculation data
Single processor code_saturne simulation.
Preprocessing calculation
Post-calculation operations
Error in preprocessing stage.
Then I check file "preprocessor.log" :
/******/******/Code_Saturne/6.1.0/code_saturne-6.1.0/arch/Linux_x86_64/libexec/code_saturne/cs_preprocess
--log --out mesh_input.csm
/mnt/Partage/obstacle/case1/../MESH/obstacle_ADF_sansAIR.cgns
| Code_Saturne Preprocessor |
code_saturne version 6.1.0 (built Thu May 7 15:33:04 2020)
CGNS 4.1.0 file format support
Reading of compressed files ('.gz') with Zlib 1.2.11
Case configuration
Date : Thu Jun 18 15:08:49 2020
System : Linux 5.4.0-37-generic
Machine : ******-VirtualBox
Processor : AMD Ryzen 9 3950X 16-Core Processor
Memory : 32113500
User : ****** (******)
Directory : /mnt/Partage/obstacle/case1/RESU/case
Case name : preprocess
Mesh file : /mnt/Partage/obstacle/case1/../MESH/obstacle_ADF_sansAIR.cgns
Reading mesh from file in CGNS format
Mesh file: /mnt/Partage/obstacle/case1/../MESH/obstacle_ADF_sansAIR.cgns
CGNS version : 3.2
Base name : BASE#1
Physical dimension : 3
Cell dimension : 3
Number of zones : 1
Zone 1: "obstacle_ADF_sansAIR"; type "Unstructured"
1316165 vertices; 3308980 cells
(cartesian coordinates, "RealDouble" precision, unit "Null")
Section 1: "SOLIDE_1_1_SOLID";
(indices 1 to 3308980, type "MIXED")
Section 2: "INLET";
(indices 3308981 to 3312062, type "MIXED")
Section 3: "OUTLET";
(indices 3312063 to 3315144, type "MIXED")
Section 4: "WALL";
(indices 3315145 to 3527398, type "TRI_3")
CGNS boundary condition information:
Zone 1
BC 1: "INLET" ("UserDefined" on "FaceCenter")
BC 2: "OUTLET" ("UserDefined" on "FaceCenter")
BC 3: "WALL" ("UserDefined" on "FaceCenter")
Number of vertices : 1316165
/home/******/CodeSaturne/code_saturne-6.1.0/preprocessor/pre-post/ecs_pre_cgns.c:2136: Fatal error.
CGNS error:
cgio_read_all_data_type:ADF 54: A node-id of 0.0 is not valid.
Call stack
1: 0x55da598914d6 <+0xf4d6> (cs_preprocess)
2: 0x55da59896768 <ecs_pre_cgns__lit_maillage+0x1e78> (cs_preprocess)
3: 0x55da598906cc <ecs_pre__lit_maillage+0xec> (cs_preprocess)
4: 0x55da59888f10 <main+0xa0> (cs_preprocess)
5: 0x7f1f1461b0b3 <__libc_start_main+0xf3> (libc.so.6)
6: 0x55da5988974e <_start+0x2e> (cs_preprocess)
Whatever boundary zones and boundary conditions, the error message is
"CGNS error:
Therefore, I think it is not a problem with boundary zones defined in GUI but a problem with the importation of CGNS !
When I import CGNS, boundary zones are not loaded automatically into GUI and I must set them manually.
If you have ever resolved same problem, I will enjoy understanding how you proceed !
In general, I am interested in importation Ansys mesh to Code_Saturne 6.1
I am not a specialist of Linux...
Thank you !
Re: Ansys CGNS to Code_Saturne 6.1
Some CGNS files generated by older CGNS libraries are not readable directly without recent CGNS versions (due in part to changes in the handling of Polyhedra, but since CGNS tries to achieve backwards and forwards compatibility, the cause is probably more subtle than I can explain).
In any case, when you installed CGNS with code_saturne, in the "bin" subfolder of the CGNS installation, you should find a "cgnsupdate" file. Try running:
<path_to_cgns_bin>/cgnsupdate <your_cgns_file>
and see if you can read it afterwards (in any case, this has worked for colleagues using ANSYS meshing also).
Marsang
Post by Marsang »
Thank you Yvan !
The conversion file works but the problem is the same when I am running Code_Saturne 6.1.
I have ever tryed with ADF and HDF5 with last version and 2.5 version but errors are same...
I can join my .xml file and my .cgns file if you want. It is a simple tube.
Thank you in advance to any one who may be able to give me some ideas to imprt Ansys mesh to Code_Saturne !
Tube.cgns
(344 KiB) Downloaded 224 times
case3.xml
(8.25 KiB) Downloaded 199 times
Running "cgnsupdate" on your file fails, and "cgnscheck" on your file complains (CGNSlib ERROR:cg_open:Error: ElementStartOffset defined more than once) using CGNS 4.1, but seems OK using CGNS 3.3.
Is the file you attached the file before you ran cgnsupdate or after ? If possible, I would like to test using the original case.
Since it seems OK with CGNS 3.3, iy you reinstall code_saturne using CGNS 3.3 (if you used the automatic installer, replace 4.1 with 3.1 for CGNS in that file), you should be OK.
This also means there seems to be a compatibility issue between CGNS versions, which we will probably need to report to the CGNS developers once this is verified.
Marsang
Post by Marsang »
Thank you Yvan !
You can find original CGNS attached, and original case is Simple_Junction case without mesh. I have just removed original mesh ".des" I have replaced it by my CGNS mesh and rename boundary zones with Ansys named selections (I think it is the way...). CGNS attached are not converted by "cgnsupdate".
I have ever tried with 2.5 and 3.2 version, without success...
Tube.zip
(753.22 KiB) Downloaded 215 times
Did you reinstall code_saturne with CGNS 3.3, or simply change the output version in ANSYS ? In past versions at least, ANSYS meshing (or ICEM CFD at the time) would lie on the CGNS file version (by setting a different version number but not really using a different library version).
Marsang
Post by Marsang »
Hello !
My problem is resolved. I have downloaded CAELinux 2018 suite with Code-Saturne 5.0.4 and I can import easily CGNS 3.2.
Thank you Yvan !
Is it OK with you if I send use your mesh to report the bug to the CGNS team ?
Marsang
Post by Marsang »
Of course !
Tube_ADF_CGNS_3.1.cgns
(328 KiB) Downloaded 261 times
Tube_ADF_CGNS_3.2.cgns
(328 KiB) Downloaded 270 times
Tube_HDF5_CGNS_3.1.cgns
(337.98 KiB) Downloaded 248 times
