"Preprocessing stage required but no mesh is given"
Re: "Preprocessing stage required but no mesh is given"
Can you test replacing the bin/cs_case_domain.py with the attached file, then post the output from the script ?
- cs_case_domain.py
- (63.53 KiB) Downloaded 515 times
I pasted the script you provided in
which is where the original script was present.
The results have not changed. The attachment has the output directories of both before and after replacing with the script you provided. Am I doing as you intended?
/home/.../code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturneThe results have not changed. The attachment has the output directories of both before and after replacing with the script you provided. Am I doing as you intended?
- RESU.tar.gz
- (4.78 KiB) Downloaded 487 times
What I am interested in is not the output directory at this stage, but the messages in the terminal from which you ran the code, or the GUI run window contents if run from the GUI (because my modification should simply add additional messages to try to understand where things go wrong).
here is the output at the terminal:
I couldnt find much difference except that the error earlier appeared at line 896 (post # 6 in this thread) and this time at line 900.
Anand
Code_Saturne
Version: 6.0
Path: /home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64
Result directory:
/home/anands/Documents/Code_Saturne_Sims/Verify-VolumeHeatSource/Case-2-MiddleStove/RESU/20191028-1656
Preparing calculation data
Preprocessing calculation
File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/bin/code_saturne", line 76, in <module>
retcode = cs.execute()
File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_script.py", line 93, in execute
File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_script.py", line 170, in run
File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_run.py", line 329, in main
return run(argv, pkg)[0]
File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_run.py", line 317, in run
stages=stages)
File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_case.py", line 2042, in run
mpiexec_options)
File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_case.py", line 1738, in preprocess
d.preprocess()
File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_case_domain.py", line 900, in preprocess
raise RunCaseError(err_str)
cs_case_domain.RunCaseError: Preprocessing stage required but no mesh is given
Anand
It seems the problem occurs quite early, and the instrumentation might print empty lines.
I added some additional logging to the attached files. Could you try again with those ?
- cs_xml_reader.py
- (11.45 KiB) Downloaded 560 times
- cs_case_coupling.py
- (11.41 KiB) Downloaded 493 times
- cs_run.py
- (11.39 KiB) Downloaded 526 times
the following is the error report, for the files you have attached:
Anand
File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_run.py", line 330, in main
File "/home/anands/Documents/CODE_SATURNE/Code_Saturne/6.0.0/code_saturne-6.0.0/arch/Linux_x86_64/lib/python3.6/site-packages/code_saturne/cs_run.py", line 318, in run
stages=stages)
mpiexec_options)
d.preprocess()
If you only post the backtrace and not the previous lines, I won't be able to do much.
sorry for the mistake, here is the full listing:
cs_run.py: param = None
read_parameter_file_1 None
Code_Saturne
Version: 6.0
Result directory:
/home/anands/Documents/Code_Saturne_Sims/Verify-VolumeHeatSource/Case-2-MiddleStove/RESU/20191029-1518
stages=stages)
mpiexec_options)
d.preprocess()
It seems the parameters file is not passed to the execution script.
Do you start the code with the GUI or directly running the "runcase" file from a terminal ? Could you post your runcase in SCRIPTS ?
