I am dealing with a case consisting in simulating a flow between two moving plates. The movement of these plates is imposed. The problem is that the internal mesh don't follow the plate displacement, even when I use a big mesh viscosity (see joined picture). I'll like to know how to impose mesh displacement with Code_Saturne 5.0.
Thank you.
Djeen.
Impose mesh displacement
Re: Impose mesh displacement
What does the mesh displacement visualization look like ? Your figure does not show the deformation field, only the viscosity. I recommend also using the extract block filter (or separate meshes writer option in Code_Saturne) to separate boundary and volume meshes in ParaView.
Hello
Please find attach the mesh displacement visualization and the runcase. The separate meshes writer in Code_Saturne doesn't anything.
Best regards.
Best regards.
- ALE_Plaques.xml
- run case
- (8.22 KiB) Downloaded 173 times
I probably will not have the time to check your setup in the next 2 weeks.
The fact that the boundary cells are much wider than the following cells probably leads to very small deformation inside the mesh. Uding a more regular mesh will provide better résults in most cases.
Hello Djeen,
In your xml file (case) you set fixed_displacements for two boundaries (upper and lower I guess), and fixed_boundary for the rest. So, the boundary nodes con't move. You have to set sliding boundary. I think that this is the problem.
Hello Luciano,
With the sliding boundary, I have a good mesh motion. Thanks.
I have another problem. I received the following error. I don't know if it depend of my parameters or if it's an internal thing of Code_Saturne. Can you or somebody explain it to me.
Best regards.
Signal SIGTERM (terminaison) reçu.
--> calcul interrompu par l'environnement.
Pile d'appels :
1: 0x7f0ed2711ce6 <+0x12ce6> (mca_btl_openib.so)
2: 0x7f0ed6837eda <opal_progress+0x4a> (libopen-pal.so.13)
3: 0x7f0ed7cac565 <ompi_request_default_wait_all+0x235> (libmpi.so.12)
4: 0x7f0ed7ce626f <PMPI_Waitall+0x9f> (libmpi.so.12)
5: 0x7f0eda6d6fe9 <cs_halo_sync_var_strided+0x459> (libsaturne.so.5)
6: 0x7f0eda8e3f37 <cs_gradient_vector+0xa7> (libsaturne.so.5)
7: 0x7f0eda6d0bb2 <cs_field_gradient_vector+0xb2> (libsaturne.so.5)
8: 0x7f0eda6d0c6f <cs_f_field_gradient_vector+0x5f> (libsaturne.so.5)
9: 0x7f0eda6501af <alemav_+0x2cf> (libsaturne.so.5)
10: 0x7f0eda656fa4 <caltri_+0x1ff4> (libsaturne.so.5)
11: 0x7f0eda627c2f <cs_run+0x56f> (libsaturne.so.5)
12: 0x7f0eda62757f <main+0x12f> (libsaturne.so.5)
13: 0x7f0ed7495b15 <__libc_start_main+0xf5> (libc.so.6)
14: 0x400989 <> (cs_solver)
Fin de la pile
Signal SIGSEGV (accès à une zone mémoire interdite) intercepté !
Pile d'appels :
1: 0x7f6f38d07104 <clipsa_+0x1d0> (libsaturne.so.5)
2: 0x7f6f38d378b5 <turbsa_+0x2315> (libsaturne.so.5)
3: 0x7f6f38ac2d5d <tridim_+0x61ad> (libsaturne.so.5)
4: 0x7f6f3895ae12 <caltri_+0x1e62> (libsaturne.so.5)
5: 0x7f6f3892bc2f <cs_run+0x56f> (libsaturne.so.5)
6: 0x7f6f3892b57f <main+0x12f> (libsaturne.so.5)
7: 0x7f6f35799b15 <__libc_start_main+0xf5> (libc.so.6)
8: 0x400989 <> (cs_solver)
Fin de la pile
Best regards.
Pile d'appels :
Fin de la pile
Pile d'appels :
Fin de la pile
Which exact version (5.0.x release) of the code are you using, and on which type of system ?
Do you have user C or Fortran files, or only the XML definition ?
I'm using the version 5.0.9 of Code_Saturne. The OS is Mageia version 6.
I'm only using the XML definition.
I forgot to say that simulation are launched on a cluster.
Djeen
Djeen
The error looks like a missing parallel sync or inconsistent check issue.
Could you post your mesh also (directly if it is not too big, using a link otherwise).
And if possible, the partition_output directory from the execution directory, so as to reproduce in the same partitioning.
The following link is for the mesh.
https://1drv.ms/u/s!Ahb7Y7V_16BngRA21BtvmBtSUBVe
Find attached the execution directory.
- Fichiers.zip
- All files
- (1.98 MiB) Downloaded 172 times
