Problem Installing Salome 8.5 with Code_Saturne 5.0.9
Mohammad
Post by Mohammad »
First, I installed Salome 8.5.
It has been installed in the directory: "/home/mohammad/salome".
Then, I installed Code_Saturne 5.0.9 Autumatically and edited setup file to this one:
(Just edited the installation directory and Defined salome installation path)
# Setup file for Code_Saturne installation
# Download packages ?
download  yes
# Language
#   default: "en" english
#   others:  "fr" french
language  en
# Install Code_Saturne with debugging symbols
debug     no
# Installation directory
prefix    /home/mohammad/cfd/Code_Saturne/5.0.9
# Optional architecture Name (installation subdirectory)
use_arch  no
arch      Linux_x86_64
# C compiler and optional MPI wrapper
compC     /usr/bin/cc
mpiCompC  auto
# Fortran compiler
compF    /usr/bin/f95
# C++ compiler and MPI wrapper for optional packages
# Required only for static builds using the MED library
# or for build of optional modules such as MEDCoupling
# support.
compCxx     /usr/bin/c++
mpiCompCxx  auto
# Python interpreter.
python    /usr/bin/python
# Disable the Graphical user Interface ?
disable_gui  no
# Disable frontend (also disables GUI) ?
# May be useful for debug builds and HPC cluster builds
# installed side-by side with a full build.
disable_frontend  no
# Optional SALOME platform install path.
# This is the path for the main SALOME directory,
# not the application directory.
# If Code_Saturne is built with SALOME support,
# running "code_saturne salome" will launch the
# associated application, containing the CFDSTUDY module.
salome    /home/mohammad/salome
# Optional packages:
# MED / HDF5  For MED file format support
#             (used by SALOME and by Gmsh)
# CGNS / HDF5 For CGNS file support
#             (used by many meshing tools)
# Scotch (includes PT-Scotch) and/or ParMetis
# for parallel partitioning
#   For Linux workstations, HDF5, CGNS, and even MED
# packages may be available through the package manager.
# HDF5 is also often available on large systems.
# When building with SALOME, the platform distribution's
# packages may be used, by setting in the matching entry
# 'yes' under the "Use" column and simply 'salome' under
# the path column.
# Scotch and Pt-Scotch are available in some Linux
# distributions, but may be built with options
# incompatible with non-threaded Code_Saturne runs.
#   To install CGNS or ParMetis, the CMake
# configuration/installation tool is required
# (it is available in most Linux distributions)
#   Libxml2 is needed to read XML files output by the
# Graphical User Interface. It is generally available
# through the package manager.
#  Name    Use   Install  Path
hdf5       no    no       None
cgns       no    no       None
med        no    no       None
scotch     no    no       None
parmetis   no    no       None
libxml2    auto  no       None
Now, after the code_saturne is installed when I want to use "code_saturne salome" it says:
"SALOME is not available in this installation."
What's The Problem?
Re: Problem Installing Salome 8.5 with Code_Saturne 5.0.9
SALOME is often installed in two subdirectories, for example appli_V8_5 and Salome-V8_5...
The path you need to specify is the one of the main part of the installation, usually named Salome-Vx_y... (we cannot simply use the top-level "salome" directory because it can sometimes contain multiple installations).
