zero velocity at the wall
Ionut G
Post by Ionut G »
I am trying to set from "cs_user_boundary_conditions.f90" zero velocity at the wall.
I am using this code:
call getfbr('PLATE', nlelt, lstelt)
do ilelt = 1, nlelt
  ifac = lstelt(ilelt)
  rcodcl(ifac, iu, 1) = 0.d0
  rcodcl(ifac, iv, 1) = 0.d0
  rcodcl(ifac, iw, 1) = 0.d0
I get this error: SIGSEGV signal (forbidden memory area access) intercepted!
What I'm doing wrong?
Thank you,
ionut
Re: zero velocity at the wall
Did you allocate the lstelt array?
Ionut G
Post by Ionut G »
yes, i've allocated it.
I attached the file too.
Thank you,
Ionut
(20.88 KiB) Downloaded 192 times
Why did you comment some arguments from the cs_f_user_boundary_conditions subroutine ?
This is probably the cause of the crash.
Ionut G
Post by Ionut G »
I thought that if I don't need them I could comment them. I didn't want to use more memory if is not needed for the software.
I uncommented them and now is working.
Thank you,
Ionut
