coupling with code_aster deformation issues
Re: coupling with code_aster deformation issues
Hello Yvan and Luciano,
I was struggling with my case until this morning. I made the change as recommended by Luciano (thanks by the way), and it seems to work now ! I need to make some experimental comparisons and I'll keep you informed.
Paul
Paul
Looking at the sources, asddlf is set either by a user subroutine or by the GUI, in uiaste from the src/gui/cs_gui_mobile_mesh.c file.
It might be interesting to print the values there to see what is going on (because those values do not otherwise seem to be modified, unless you are also modifying them in a user subroutine). You can simply copy that file to the SRC directory of your case and editi it for testing (not recommended general practice for development, but should work for debugging here).
Luciano Garelli
I get this
And if print the asddlf in the strdep.f90 where it is used
I get
I was cheking that the array is created as a bi-dimensional array in fortran in alaste.f90 (integer, save :: asddlf(3,nastmx), asddlc(3,nastmx)), then is set in a C function (asddlf[istruct * 3 + 0] = _get_external_coupling_dof(label, "DDLX") ? 0 : 1;) ans finally used in a fortran subrutine. May be the problem can be here, because as you mention this array is not overwritted
This is what I did to find the error. I copy the cs_ast_coupling.c, cs_gui_mobile_mesh.c, strdep.f90 and start to print values. If I print the values after the set of the asddlf in cs_gui_mobile_mesh.cIt might be interesting to print the values there to see what is going on (because those values do not otherwise seem to be modified, unless you are also modifying them in a user subroutine). You can simply copy that file to the SRC directory of your case and editi it for testing (not recommended general practice for development, but should work for debugging here)
/* Get DDLX, DDLY and DDLZ values */
asddlf[istruct * 3 + 1] = _get_external_coupling_dof(label, "DDLY") ? 0 : 1;
asddlf[istruct * 3 + 2] = _get_external_coupling_dof(label, "DDLZ") ? 0 : 1;
bft_printf("istruct %d, ASDDLF_X %d, ASDDLF_Y %d, ASDDLF_Z %d \n",istruct, asddlf[istruct * 3 + 0], asddlf[istruct * 3 + 1], asddlf[istruct * 3 + 2]);Code: Select all
istruct 0, ASDDLF_X -1878870816, ASDDLF_Y 6370896, ASDDLF_Z -1 Code: Select all
do ii = 1, 3
forast(ii,indast) = asddlf(ii,-istr)*forbr(ii,ifac)
enddoCode: Select all
DDLX= 0.00000E+00, DDLY= 1.0727E+09, DDLZ= 0.00000E+00Regards,
Hello Luciano,
Looks like asddlf is declared as an integer in Fortran and a double in C... That is probably the error (because the interleaving seems ok).
Could you try swiching it to int in C ? Both in the .c and .h files...
Luciano Garelli
Yes...you are right. I change the declaration in the .c and .h files to an integer and now the output is OK
Thanks for your help!
istruct 0, ASDDLF_X 1, ASDDLF_Y 1, ASDDLF_Z 1 Regards,
Luciano Garelli
Hello Yvan and Paul,
In a previous post I mention that the restart dosen't work given an error about differences in the simulation time. The problem was that I don't update the start_time in the coupling_parameters.py for the FSI_coupler.
Now I can restart the simulation from a previous run.
Hello Luciano,
Thanks for the update. I'll push to integer/double fix into Git tomorrow, so the next releases (5.2.1, 5.1.5, and 5.0.9) will have the fix.
Good that this coupling finally seems to be useful...
Hi Luciano and Yvan,
I'm trying to use the restart option (with aster coupling) and it causes some trouble with the ALE module. To be clear, the restart works but does not take into account the mesh viscosity set in the previous simulation by setting it equals to 1 in the whole domain.
Did you face this problem ?
Yvan, can I use a function to modify the mesh viscosity in the domain, as in the GUI ?
Paul
Paul
Luciano Garelli
Hello Paul,
Yes, few days ago I restart a calculation and I faced the same problem...the mesh viscosity was not changed with the new distribution, but I don't know if it is a bug or you can't change the mesh viscosity due to matrix assembling, solver, etc. in a restart.
I don't tested if the same problem occurs solving only a fluid dynamic case.
As I did not run your case, I am not sure: did you set the mesh viscosity using a user subroutine or simply the GUI ?
In any case, it should be handled, but I suspect the setting is skipped by the restart (it this is what I understand).
Do you have warnings about values not read in the restart file ? Especially regarding ALE ? The values should normally be read.
In src/base/lecamx.f90 the tests on "iortvm" seem to indicate the viscosity is read only for anisotropic cases, which seems strange... So you might want to change the test (line 834 on master branch) from:
to:
Also, if the previous case was not using ALE, this will not be enough. In src/base/phyvar.f90 (line 654 on master branch),
should be replaced by:
or even
Better yet, the corresponding section should be in iniva0 if we want it to be always initialized (but overwriten by the restart), or inivar (if we want the current values to have priority). I prefer the second option, in which case it is probably not even useful to have this in the restart file, except for really complex user cases.
I'll let you test changing these files...
if (iortvm.eq.1) then
if (jortvm.ne.1) thenCode: Select all
if (.true.) then
if (jortvm.ne.1) thenAlso, if the previous case was not using ALE, this will not be enough. In src/base/phyvar.f90 (line 654 on master branch),
if (iale.eq.1.and.ntcabs.eq.0) thenCode: Select all
if (iale.eq.1.and.ntcabs.eq.ntpabs) thenCode: Select all
if (iale.eq.1.and.ntcabs.le.ntpabs-1) thenI'll let you test changing these files...
