Could you tell the definition of user roughness parameter which is set up in the GUI. Is it "ks" value (Nikuradze roughness) or "y0" value. Or some other value?
In the source code (https://www.code-saturne.org/cms/sites/ ... ource.html) there is next lines about roughness:
688 /* Compute the friction velocity ustar */
689
690 /* Shifting of the wall distance to be consistant with
691 * the fully rough wall function
692 *
693 * ln((y+y0)/y0) = ln((y+y0)/alpha xi) + kappa * 5.2
694 *
695 * y0 = roughness * exp(-kappa * 8.5)
696 * */
697 double y0 = roughness*exp(-cs_turb_xkappa*cs_turb_cstlog_rough);
