Hello CS team!
I try to use the drift flux model in CS 5 (and CS4) without activating thermal model (I don't need thermophoresis).
I flagged the corresponding entries in cs_user_parameters.f90 file and I used cs_user_physical_propreties-scalar_drift.f90 (in SRC/EXAMPLES) for setting up my case but CS need a variable diffusivity for this scalar :
@ @@ ATTENTION : ARRET LORS DU CALCUL DES GRANDEURS PHYSIQUES
@ DONNEES DE CALCUL INCOHERENTES
@ Pour le scalaire 1
@ la diffusivite est uniforme alors que
@ usphyv impose une diffusivite variable.
@ Le calcul ne sera pas execute.
@ Modifier usipsu ou usphyv.
My question is following : is it possible to use scalar drift flux model with a constant scalar diffusivity?
Thanks a lot for your feedback.
Jeremie
Constant Diffusivity of scalar with drift flux in CS 5.0.4?
Re: Constant Diffusivity of scalar with drift flux in CS 5.0
Is there anyone to give me an answer?
I passed some time to read sources and documentation, and I have the feeling that I can't use the drift flux model without activating 'energy' model in cs even if I don't use it (isothermal case).
Thanks for a reply.
Jeremie
Thanks for a reply.
Jeremie
Hello Jeremie,
I'm not too sure about this. I'll check with Martin who worked on that part of the code, and keep you updated.
You can activate a variable diffusivity and give the same value for all the cells. We have to correct this combination.
Martin
Martin
Dear Martin,
Thanks for your reply.
Should I also activate thermal model even if I don't use it?
Best Regards,
Jeremie
Best Regards,
Jeremie
Ok, I finally get some results without activating thermal model with a constant diffusivity for scalar.
Thanks a lot for your help!
Jeremie
Jeremie
