I have a question about preparation of the geometry before lunching Code_Saturne,
I am using Gmshs to generate my grid with tetrahedrons, and as I know, to fix the element size I can do it by points or by an element size factor, I am wondering if it is possible to do it both ways, to precise some of points size and let the rest of grid generate following the element size factor, I have tried it and it blocks each time,
Thanks for any help,
Gmsh - element size factor
Re: Gmsh - element size factor
I do not see how this relates to the subject matter of this forum. Maybe a specific section would be useful for this sort of question, but the general usage forum would be better.
In any case you will probably have more luck on a Gmsh forum, as only a subset of users here use Gmsh or know it well.
ok, you are right,
I will focus on a gsmh forum
Houda
Houda
