Problem with libple.so.2
Re: Problem with libple.so.2
I have the folder of OpenMPI installed in the same path than you : /usr/lib/x86_64-linux-gnu/openmpi
I try the command line:
Code_Saturne configure --with-mpi=/usr/lib/x86_64-linux-gnu/openmpi
but it doesnt do nothing, only the message with all the command associated with the use of CS.
The error when I try to run a case in parallel is stil the same.
Julien
Julien
Step1: be sure you have necessary development packages installed:
Step2: configure code_saturne with mpi support (please note the last 3 lines):
Step3: make and make install as usual.
It should work. If not, give the error message or upload config.log again.
Good luck.
It sounds like you didn't do it the right way. You have to rebuild code_saturne with mpi support before you can use it.I try the command line:
sudo apt install libopenmpi-dev openmpi-bin
configure \
--prefix=/home/julien/code_saturne/7.2.0/code_saturne-7.2.0/arch/Linux_x86_64 \
--with-hdf5=/home/julien/code_saturne/7.2.0/hdf5-1.10.6/arch/Linux_x86_64 \
--with-cgns=/home/julien/code_saturne/7.2.0/cgns-4.3.0/arch/Linux_x86_64 \
--with-med=/home/julien/code_saturne/7.2.0/med-4.1.1/arch/Linux_x86_64 \
--without-metis \
--without-scotch \
PYTHON=/usr/bin/python3 \
--disable-static \
CXX=mpicxx \
CC=mpicc \
Good luck.
Thank you for your help.
I have done
./configure
CXX=mpicxx \
CC=mpicc \
make
make install (in admin mode)
But it still complains with the error
/cs_solver was built without MPI support,
so option "--mpi" may not be used.
Check run_solver.log and error* files for details.
Domain None (code_saturne):
run_solver.log, error*.
Here is the config.log file
Thank you very much
Julien
I have done
./configure
CXX=mpicxx \
CC=mpicc \
make
Thank you very much
Julien
No, you didn't. Otherwise you have uploaded a wrong config.log.I have done
./configure
CXX=mpicxx \
CC=mpicc \
Don't install as root. Not necessary because you install to your own home directorymake
(-- refix=/home/julien/code_saturne/7.2.0/code_saturne-7.2.0/arch/Linux_x86_64) nor a good idea because there may be some side effects when you launch as ordinary user.
I have start a fresh install of CS7.2. I try Debian but I have several freeze so I come back on Ubuntu.
I have follow each steps of this video
https://www.youtube.com/watch?v=iwke0YRpMrE
I have errors during installation.
See my config.log file.
What I have done wrong?
Julien
Julien
- config.log
- (16.89 KiB) Downloaded 78 times
The important part in your config.log is here:
With, a few lines earlier:
So it seems your "/usr/bin/mpicc" wrapper is not working. You may want to reinstall the Ubuntu MPI wrappers / packages.
Otherwise, try compiling any simple "hello world" C program (MPI or not) with it, and if it fails, this might be an Ubuntu packaging bug...
configure:4952: error: in `/home/julien/Code_Saturne/code_saturne-7.2.0.build':
configure:4954: error: C compiler cannot create executables
configure:4883: checking whether the C compiler works
configure:4905: /usr/bin/mpicc conftest.c >&5
/usr/bin/ld: cannot find -lmpi: No such file or directory
/usr/bin/ld: cannot find -lopen-rte: No such file or directory
/usr/bin/ld: cannot find -lopen-pal: No such file or directory
/usr/bin/ld: cannot find -lhwloc: No such file or directory
/usr/bin/ld: cannot find -levent_core: No such file or directory
/usr/bin/ld: cannot find -levent_pthreads: No such file or directory
Did you try Step1~Step3 in my previous post? It should work for Ubuntu 22.04. But from your latest config.log it seems you didn't. Without Step1, you won't have compiler wrappers (/usr/bin/mpicc and /usr/bin/mpicxx) and mpi header files; withou setting '--with-mpi=/usr/lib/x86_64-linux-gnu/openmpi' in Step3 the mpi library and header files won't be found.
I have re-install properly CS7.2 on Ubuntu 22.10, everything works well none.
Julien
Julien
As a "I have the same" comment, on Ubuntu I see the same problem. While not that big of a deal, if there was a general solution that fit into the install stage, it would be preferred; for now I just run "export LD_LIBRARY_PATH..." each time in a new shell, as I keep multiple versions on my machine, and anyway don't like messing with bashrc unless necessary. With older code_saturne, it was never an issue.
