error during ../code_saturne-7.0.5/install_saturne.py
Posted: Fri Sep 02, 2022 5:41 pm
by jacob
I am trying to install code_saturne according to https://www.youtube.com/watch?v=iwke0YRpMrE
but the installation fails.
Installation of Code_Saturne
____________________________
The process will take several minutes.
You can have a look at the log file meanwhile.
Check the setup file and some utilities presence.
o Checking for cc... /usr/bin/cc
o Checking for f95... /usr/bin/f95
o Checking for python3... /usr/bin/python3
Python version is 3.8
o Checking for make... /usr/bin/make
Download of HDF5
(https://support.hdfgroup.org/ftp/HDF5/r ... 0.6.tar.gz)
Download of CGNS
(https://github.com/CGNS/CGNS/archive/v4.1.2.tar.gz)
Download of MED
(http://files.salome-platform.org/Salome ... 1.0.tar.gz)
Download of scotch
(https://gitlab.inria.fr/scotch/scotch/- ... 1.0.tar.gz)
Download of parmetis
(http://glaros.dtc.umn.edu/gkhome/fetch/ ... 0.3.tar.gz)
File "/usr/lib/python3.8/urllib/request.py", line 1354, in do_open
h.request(req.get_method(), req.selector, req.data, headers,
File "/usr/lib/python3.8/http/client.py", line 1256, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/lib/python3.8/http/client.py", line 1302, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/lib/python3.8/http/client.py", line 1251, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/lib/python3.8/http/client.py", line 1011, in _send_output
self.send(msg)
File "/usr/lib/python3.8/http/client.py", line 951, in send
self.connect()
File "/usr/lib/python3.8/http/client.py", line 922, in connect
self.sock = self._create_connection(
File "/usr/lib/python3.8/socket.py", line 808, in create_connection
raise err
File "/usr/lib/python3.8/socket.py", line 796, in create_connection
sock.connect(sa)
TimeoutError: [Errno 110] Connection timed out
During handling of the above exception, another exception occurred:
File "../code_saturne-7.0.5/install_saturne.py", line 1354, in <module>
setup.install()
File "../code_saturne-7.0.5/install_saturne.py", line 1092, in install
p.download()
File "../code_saturne-7.0.5/install_saturne.py", line 246, in download
urllib.request.urlretrieve(self.url, self.archive)
File "/usr/lib/python3.8/urllib/request.py", line 247, in urlretrieve
with contextlib.closing(urlopen(url, data)) as fp:
File "/usr/lib/python3.8/urllib/request.py", line 222, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib/python3.8/urllib/request.py", line 525, in open
response = self._open(req, data)
File "/usr/lib/python3.8/urllib/request.py", line 542, in _open
result = self._call_chain(self.handle_open, protocol, protocol +
File "/usr/lib/python3.8/urllib/request.py", line 502, in _call_chain
result = func(*args)
File "/usr/lib/python3.8/urllib/request.py", line 1383, in http_open
return self.do_open(http.client.HTTPConnection, req)
File "/usr/lib/python3.8/urllib/request.py", line 1357, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [Errno 110] Connection timed out>
I would appreciate any help.
Re: error during ../code_saturne-7.0.5/install_saturne.py
Posted: Fri Sep 02, 2022 7:13 pm
by jacob
I tried replacing
self.packages['parmetis'] = \
Package(name="parmetis",
description="ParMETIS",
package="parmetis",
version="4.0.3",
archive="parmetis_4.0.3.orig.tar.gz",
url="https://launchpad.net/ubuntu/+archive/p ... 4.0.3-4/%s")
in install_saturne.py but now I got this error
Download of HDF5
Download of CGNS
Download of MED
Download of scotch
(https://launchpad.net/ubuntu/+archive/p ... rig.tar.gz)
HDF5 (Hierarchical Data Format)
version: 1.10.6
url: https://support.hdfgroup.org/ftp/HDF5/r ... 0.6.tar.gz
package: hdf5
source_dir: None
install_dir: /home/vojta/Code_Saturne/7.0.5/hdf5-1.10.6/arch/Linux_x86_64
config_opts: --enable-build-mode=production
Extract of HDF5
Installation of HDF5
version: 1.10.6
package: hdf5
source_dir: /home/vojta/Code_Saturne/code_saturne.build/hdf5-1.10.6
o Configure...
o Compile...
o Install...
o Clean...
CGNS (CFD General Notation System)
version: 4.1.2
url: https://github.com/CGNS/CGNS/archive/v4.1.2.tar.gz
package: cgns
source_dir: None
install_dir: /home/vojta/Code_Saturne/7.0.5/cgns-4.1.2/arch/Linux_x86_64
config_opts: -DCGNS_ENABLE_64BIT=ON -DCGNS_ENABLE_SCOPING=ON -DCGNS_ENABLE_HDF5=ON -DCMAKE_PREFIX_PATH=/home/vojta/Code_Saturne/7.0.5/hdf5-1.10.6/arch/Linux_x86_64 -DHDF5_INCLUDE_PATH=/home/vojta/Code_Saturne/7.0.5/hdf5-1.10.6/arch/Linux_x86_64/include
Extract of CGNS
Installation of CGNS
version: 4.1.2
package: cgns
source_dir: /home/vojta/Code_Saturne/code_saturne.build/CGNS-4.1.2
o Configure...
o Compile...
o Install...
o Clean...
MED (Model for Exchange of Data)
version: 4.1.0
url: http://files.salome-platform.org/Salome ... 1.0.tar.gz
package: med
source_dir: None
install_dir: /home/vojta/Code_Saturne/7.0.5/med-4.1.0/arch/Linux_x86_64
config_opts: --with-med_int=long --disable-fortran --disable-python --with-hdf5=/home/vojta/Code_Saturne/7.0.5/hdf5-1.10.6/arch/Linux_x86_64
Extract of MED
Installation of MED
version: 4.1.0
package: med
source_dir: /home/vojta/Code_Saturne/code_saturne.build/med-4.1.0
o Configure...
Error during configure stage of MED.
See install_saturne.log for more information.
Posted: Sat Sep 03, 2022 12:44 pm
The error seems to be in MED installation. Could you post the full install_saturne.log file so I can check what is wrong ?
We might simply need to adjust some build options for MED depending on your type of Linu distribution.
What Linux distribution are you running on ?
Posted: Sat Sep 03, 2022 6:06 pm
by jacob
Hello, thanks for reply.
doing sudo apt-get install libhdf5-serial-dev
solved the problem, but I had to do
hdf5 yes yes None
cgns yes yes None
med yes yes None
scotch no no None
parmetis no no None
but someone should check the parmetis tar, because it does not work. That caused the first problem.
when installing scotch error occurred too
My whole installation process on wsl2
sudo apt-get update
sudo apt-get install build-essential
sudo apt-get install gfortran
sudo apt-get install gcc
sudo apt-get install g++
sudo apt-get install make
sudo apt-get install cmake
sudo apt-get install python
sudo apt-get install python3
sudo apt install python3-pyqt5
sudo apt install pyqt5-dev-tools pyqt5-dev
mkdir Code_Saturne
cd Code_Saturne
wget https://www.code-saturne.org/releases/c ... 0.5.tar.gz
sudo tar -xvzf code_saturne-7.0.5.tar.gz
mkdir code_saturne.build
cd code_saturne.build
#edit setup
Do I need scotch and parmetis? Code saturne gui runs fine so far.
Posted: Sun Sep 04, 2022 12:10 am
Both PT-SCOTCH and ParMetis are optional, as code_saturne allso has a build-in (space-filling curve based) partitioner. On a cluster, they often (not always) allow improved performance through better partitioning quality, but on a workstation, they probably do not make much difference, so you'll be fine without them.
Posted: Sun Sep 04, 2022 10:01 am
by jacob
Okay, thank you.
Nevertheless, some developer should check the parmetis link because it does not work.
Posted: Mon Sep 05, 2022 7:39 pm
Yes, the link does not work anymore, ParMetis is now hosted on GitHub, but does not have any tags/releases yet, and its license is still restrictive (limited to academia, evaluation, or requires explicit permission), so I simply removed it from the installer, since the default choices led to it barely ever being used.
It is still supported by code_saturne, for those that install it on their own.
Thanks for the feedback.
Posted: Tue Sep 06, 2022 10:02 pm
by jacob
Hello, so I tried running my first study but got error
/home/vojta/Code_Saturne/7.0.5/code_saturne-7.0.5/arch/Linux_x86_64/libexec/code_saturne/cs_solver: error while loading shared libraries: libhdf5.so.103: cannot open shared object file: No such file or directory
Post-calculation operations
Error in calculation stage.
How to get this libhdf5.so.103 ?
Posted: Tue Sep 06, 2022 10:20 pm
by jacob
solved by running
export LD_LIBRARY_PATH="/usr/local/lib:$LD_LIBRARY_PATH"
before code_saturne gui
Posted: Tue Sep 20, 2022 5:23 pm
Thanks for the feedfack. I have found where that issue comes from, and fixed it on the main development branch. I'll wait for a bit of feedback before merging in to v7.0.
And in any case other users can use LD_LIBRARY_PATH as you did in the meantime.
