Code_Saturne in a docker container
Posted: Fri Mar 27, 2020 11:32 am
Following a relatively large number of installation issues (unexperienced users, exotic platforms, ...), I expose below an experiment towards a more universal way to use Code_Saturne based on Docker. Below is a Dockerfile for Code_Saturne 6.0.2 with MED and HDF5 based on Ubuntu 18:
The end of the file provides some suggestions for building the image, running the container, and activating the GUI on Linux.
I would appreciate feedback for improvements. I would also appreciate feedback from users running docker on Windows or Mac OS if they are able to activate the GUI.
Kind regards,
Cédric
FROM ubuntu:18.04 as builder
RUN apt-get update -y
RUN apt-get upgrade -y
RUN DEBIAN_FRONTEND=noninteractive apt-get install -y tzdata
RUN apt-get install -y \
wget zlib1g-dev \
vim gedit git gitk \
gfortran g++ gcc make \
python3 python3-pyqt5 \
pyqt5-dev pyqt5-dev-tools \
openmpi-bin libopenmpi2 libopenmpi-dev
RUN apt-get autoremove
RUN apt-get clean
# hdf5 1.10.6
RUN wget https://support.hdfgroup.org/ftp/HDF5/releases/hdf5-1.10/hdf5-1.10.6/src/hdf5-1.10.6.tar.gz --directory-prefix=/tmp/ \
&& tar -zxvf /tmp/hdf5-1.10.6.tar.gz -C /tmp/ \
&& rm -r /tmp/hdf5-1.10.6.tar.gz
RUN mkdir /opt/hdf5-1.10.6
WORKDIR /tmp/hdf5-1.10.6
RUN ./configure CC=mpicc FC=mpif90 CXX=mpic++ --prefix=/opt/hdf5-1.10.6 --enable-build-mode=production --enable-parallel && make -j && make install
# MED 4.0.0
RUN wget http://files.salome-platform.org/Salome/other/med-4.0.0.tar.gz --directory-prefix=/tmp/ \
&& tar -zxvf /tmp/med-4.0.0.tar.gz -C /tmp/ \
&& rm -r /tmp/med-4.0.0.tar.gz
RUN mkdir /opt/med-4.0.0
WORKDIR /tmp/med-4.0.0
RUN ./configure CC=mpicc CXX=mpic++ --prefix=/opt/med-4.0.0 --with-med_int=long --disable-python --disable-fortran --with-hdf5=/opt/hdf5-1.10.6 && make -j && make install
# Code Saturne
RUN wget http://www.code-saturne.org/cms/sites/default/files/releases/code_saturne-6.0.2.tar.gz --directory-prefix=/opt/ \
&& tar -zxvf /opt/code_saturne-6.0.2.tar.gz -C /opt/ \
&& rm -r /opt/code_saturne-6.0.2.tar.gz
RUN mv /opt/code_saturne-6.0.2 /opt/code_saturne-6.0.2_src
RUN mkdir /opt/code_saturne-6.0.2_bld /opt/saturne_tmp
WORKDIR /opt/saturne_tmp
RUN ../code_saturne-6.0.2_src/configure PYTHON=/usr/bin/python3 CC=mpicc FC=mpif90 CXX=mpic++ --prefix=/opt/code_saturne-6.0.2_bld --with-hdf5=/opt/hdf5-1.10.6 --with-med=/opt/med-4.0.0 && make -j && make install
# This is probably unsafe
# Use at your own risks
RUN chmod -R 777 /opt/hdf5-1.10.6/ /opt/med-4.0.0/ /opt/code_saturne-6.0.2_src /opt/code_saturne-6.0.2_bld
RUN echo 'root:rootpwd' | chpasswd
RUN apt-get install -y sudo gnome-terminal
RUN useradd csuser
RUN mkdir /home/csuser
RUN chown csuser /home/csuser
RUN chgrp csuser /home/csuser
RUN echo 'csuser:userpwd' | chpasswd
RUN adduser csuser sudo
USER csuser
ENV HOME /home/csuser
WORKDIR /opt/code_saturne-6.0.2_bld/bin
RUN echo "alias code_saturne="/opt/code_saturne-6.0.2_bld/bin/code_saturne"" >> /home/csuser/.bashrc
# This is probably unsafe.
# Use at your own risks.
# Build the image with:
# docker build -t cs_v6 .
# Clean all the docker images with:
# docker system prune --volumes
# [Linux] Run the container with:
# docker run -it --rm -e DISPLAY=:0 -v ${HOME}/.Xautority:/root/.Xauthority:rw --net=host --name gnome-terminal cs_v6
# [Linux] To share the local folder /aaa/bbb/ccc with the container, run the container with:
# WARNING: the container will be able to modify the corresponding folder
# docker run -it --rm -e DISPLAY=:0 -v ${HOME}/.Xautority:/root/.Xauthority:rw -v /aaa/bbb/ccc:/home/csuser/ccc --net=host --name gnome-terminal cs_v6
# [Linux] When the container is running, activate the GUI from the host:
# xhost +local:root
# [Linux] When the container is stopped, undo from the host:
# xhost -local:root
Kind regards,
Cédric
