Hi CS users,
I downloaded the trunk version. Since no "configure" file was found, I ran automake. There were errors (attached). Please help. Thanks.
- ffan
Generating "configure" file for the trunk version
- automake.zip
- (3.24 KiB) Downloaded 768 times
Re: Generating "configure" file for the trunk version
This is not sufficient. The procedure is described in the installation documentation (pdf). I'll try to remember to add it to the README.md file also.
You simply need to run ./sbin/bootstrap in the sources folder (it includes calls to automake, but not just that).
It works. Thanks.
- ffan
- ffan
