Problem Installing Salome 8.5 with Code_Saturne 5.0.9
Posted: Thu Oct 25, 2018 12:24 pm
First, I installed Salome 8.5.
It has been installed in the directory: "/home/mohammad/salome".
Then, I installed Code_Saturne 5.0.9 Autumatically and edited setup file to this one:
(Just edited the installation directory and Defined salome installation path)
Now, after the code_saturne is installed when I want to use "code_saturne salome" it says:
"SALOME is not available in this installation."
What's The Problem?
# Setup file for Code_Saturne installation
# Download packages ?
download yes
# Language
# default: "en" english
# others: "fr" french
language en
# Install Code_Saturne with debugging symbols
debug no
# Installation directory
prefix /home/mohammad/cfd/Code_Saturne/5.0.9
# Optional architecture Name (installation subdirectory)
use_arch no
arch Linux_x86_64
# C compiler and optional MPI wrapper
compC /usr/bin/cc
mpiCompC auto
# Fortran compiler
compF /usr/bin/f95
# C++ compiler and MPI wrapper for optional packages
# Required only for static builds using the MED library
# or for build of optional modules such as MEDCoupling
# support.
compCxx /usr/bin/c++
mpiCompCxx auto
# Python interpreter.
python /usr/bin/python
# Disable the Graphical user Interface ?
disable_gui no
# Disable frontend (also disables GUI) ?
# May be useful for debug builds and HPC cluster builds
# installed side-by side with a full build.
disable_frontend no
# Optional SALOME platform install path.
# This is the path for the main SALOME directory,
# not the application directory.
# If Code_Saturne is built with SALOME support,
# running "code_saturne salome" will launch the
# associated application, containing the CFDSTUDY module.
salome /home/mohammad/salome
# Optional packages:
# MED / HDF5 For MED file format support
# (used by SALOME and by Gmsh)
# CGNS / HDF5 For CGNS file support
# (used by many meshing tools)
# Scotch (includes PT-Scotch) and/or ParMetis
# for parallel partitioning
# For Linux workstations, HDF5, CGNS, and even MED
# packages may be available through the package manager.
# HDF5 is also often available on large systems.
# When building with SALOME, the platform distribution's
# packages may be used, by setting in the matching entry
# 'yes' under the "Use" column and simply 'salome' under
# the path column.
# Scotch and Pt-Scotch are available in some Linux
# distributions, but may be built with options
# incompatible with non-threaded Code_Saturne runs.
# To install CGNS or ParMetis, the CMake
# configuration/installation tool is required
# (it is available in most Linux distributions)
# Libxml2 is needed to read XML files output by the
# Graphical User Interface. It is generally available
# through the package manager.
# Name Use Install Path
hdf5 no no None
cgns no no None
med no no None
scotch no no None
parmetis no no None
libxml2 auto no None
What's The Problem?
