the tutorial about coupling CS with salome ?
binger
Post by binger »
hello,
I have installed the CS4.0.2,I want to couple the CS with the Salome.but I can not find a tutorial.please help me. I can not find the software about CFDSTUDY. my salome version is salome7.6.0
Re: the tutorial about coupling CS with salome ?
Did you use the automatic installer or manual install ?
Did you add the --with-salome configuration option to tell Code_Saturne where SALOME is installed ?
And what SALOME build did you use (there are several, with different directory strutures) ?
binger
Post by binger »
hello,
I am new here,and my English is very poor. thanks for your reply.
I used the automatic installer,so I don't know how to couple Salome with CS4.0.2.
CFDStudy is an option of Code_Saturne.
Using the automatic installer, check the "salome" entry in the "setup" file, and set it to the path of your SALOME library (not application).
On most machines, this should work.
Once this is installed, instead of using "code_saturne gui" to open a Code_Saturne GUI, you can call "code_saturne salome" to call SALOME with CFDStudy.
