Are you sure Syrthes was compiled using the same MPI ? Using the same mpicc wrapper is a solution,
running "mpicc -show" to see what that wrapper uses and adapt it to the Syrthes setup.ini is another.
Install several versions and compile with Salome and Syrthes
