PROBLEM installing code saturne 3.3.2
Re: PROBLEM installing code saturne 3.3.2
please find the enclosed setup file . i only change the language and i also put yes to the install med
- setup.txt
- (4.07 KiB) Downloaded 272 times
You also need to set download=yes.
Once the installer has run and downloaded MED (and others), it will change download to no, so if you run the installer several times, download will be set to no, and the path should be set, so you backup the "setup" file before running the installer, and compare it before and after...
Thank for your help. i follow the directives all seem to be working
Do we need to provide a password and at the end i see permission denied as shown in the file enclosed
best regards
best regards
- install_saturne.log
- (2.22 MiB) Downloaded 257 times
