Need CGNS input from ANSYS workbench
Debashis Basu
Post by Debashis Basu »
I am using SATURNE 1.3.3
I plan on using ANSYS workbench for generating grid to be used in SATURNE. That has to bein CGNS format. How can I ensure whethere CGNS has been installed properly when I installed SATURNE.
Any help or suggestion will be appreciated.
Thanks and Regards,
Debashis
Re: Need CGNS input from ANSYS workbench
If you use the install script, there is a section therein regarding CGNS. If you install everything manually, CGNS is handled in the configure script for the Preprocessor (ECS), and FVM (for post-processing).
To know if things work, just experiment with them. The code won't bite you. if you try to use a CGNS file in a study, Code_Saturne will complain if it was not built with CGNS, and will happily read CGNS files if it was built with them; simple as that.
