Error - Failed to activate module CFDSTUDY
jcastas
Post by jcastas »
I am a new user of Code_Saturne and Salome Meca.
I have started to use this for my phd studies, since it is a great tool and it is free. (Thank you EDF! :D)
I have followed several topics on this forum for the instaltion of code_saturne with Salome and now I’m doing the toturial( https://www.code-saturne.org/cms/sites/ ... _Study.pdf) of a pipe.
I’m now facing a problem with the CFDSTUDY activation. It is shows an error message like this:
“Failed to activate module CFDSTUDY”
See attached figure.
Can anyone help me on this?
PS: I'm not a Linux expert.
Thanks in advance!
João Castanheira
Print screen with error message.
Re: Error - Failed to activate module CFDSTUDY
How was Code_Saturne installed ? Was the "--with-salome=..." option used during the configure stage -this is explained in the installation manual).
Did you use the standard Salome launch command or "code_saturne salome" ?
jcastas
Post by jcastas »
Thank you for the reply.
Yes, i have installed the Code Saturne with Salome ( i think so...). I have two file attached, the installation log and setup file.
I have have initiated the salome with "code_saturne salome" on terminal. (I have added a PATH environment to the "code_saturne salome" file. So i can used anywhere on terminal.)
Terminal:
sudo -H gedit /etc/environment
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/home/joao/Code_Saturne/5.0.6/code_saturne-5.0.6/arch/Linux_x86_64/bin"
save file
Any idea of what could be the problem?
Thanks!
João
install_saturne.log
(2.02 MiB) Downloaded 1210 times
install_saturne.log
(2.02 MiB) Downloaded 1180 times
This is strange, as your configuration command seems fine (otherwise CFSTUDY would not even appear in the menus).
Do you have any logging/text messages in the terminal from which you ran "code_saturne salome" ?
jcastas
Post by jcastas »
Good morning Yvan,
when i push the CFDSTUDY i have some error messages on terminal window.
I have added some files as attachments.
thanks!
João
log_terminal.txt
terminal log information
(3.63 KiB) Downloaded 1124 times
CFDSTUDY error messages
running code_saturne salome
You might have an issue due to Salome_Meca using Qt5, and Code_Saturne using Qt4.
When both PyQt4 and PyQt5 are available on a machine, Code_Saturne 5.0 defaults to using PyQt4, while Code_Saturne 5.1 defaults to PyQt5.
To force selection of PyQt5, you can add QT_SELECT=5 to the "configure" line. Otherwise make sure PyQt5 is available, and if you do not need it for othet purposes, uninstalling PyQt4 can help.
Not 100% sure this is the cause of the issue, but the error message seems to indicate of problem of this type, or PYTHONPATH issues.
jcastas
Post by jcastas »
what do you mean by "QT_SELECT=5 to the "configure" line"? Could you explain me?
You think instaling all this Salome Meca and Code saturne 5 on a Ubuntu 16 is better?
thanks!
Did you use the general installer or "cd <build_dir> && <src_dir>/configure [options] && make && make install" approach ?
In the build directory, check the top of the "config.log" file for the "configure" command. Replay that adding QT_SELECT=5 (also explained in the installation manual). Then make && make install.
jcastas
Post by jcastas »
Ok thanks, i will try.
I have been using the python installation method.
thanks,
João
bandi
Post by bandi »
Hi all,
I still have this issue with the CFDSTUDY module. I've added the QT_SELECT=5 option to configure, removed PyQt4 from my system and also tried it in combination with salome_meca and salome 8. Still no success. It seems like the configure script doesn't process the QT_SELECT option.
Besides trying to manually replace the pyqt4 references, it there any other way to fix this?
