Page 3 of 6
Re: How to calculate scalar based on frozen average velocity?
Posted: Mon Aug 23, 2021 6:31 pm
by Tsubasa
At first I want to try your suggestion in ver.6, but is it easy to do this in ver.7?
If I use ver.6, where can I check the name of the matching field name, and use cs_field_by_name()?
Tsubasa
Posted: Mon Aug 23, 2021 8:12 pm
Which of the various suggestions are you referring to ? Defining a time moment for the mass flux can only be done after v7.0 (in v7.1/Git master), at least in the usual places. It can probably be done in v7 or v6 in cs_user_finalize_setup instead of cs_user_time_moments.
Posted: Mon Aug 23, 2021 8:36 pm
by Tsubasa
I referred the following suggestion.
Yes, it is impossible in v7.0, or at least not guaranteed : you might be able to declare a time average for the mass flux if you add the call to cs_time_moment_define_by_field_ids not in cs_user_time_moments, but in cs_user_finalize_setup (both in cs_user_parameters.c). Not sure it will work, but there might be a chance.
In v7.1, you will be able to add the definition in the usual place (i.e. cs_user_time_moments).
Now I am trying to put like the following code in cs_user_finalize_setup in the file of "cs_user_parameters.c" with ver.6 (of course I will edit the code for mass flux).
    /* Moment <U> calculated starting from time step 1000. */
    /* resulting field is a vector */
    int moment_f_id[] = {CS_F_(vel)->id};
    int moment_c_id[] = {-1};
    int n_fields = 1;
    cs_time_moment_define_by_field_ids("U_mean",
                                       n_fields,
                                       moment_f_id,
                                       moment_c_id,
                                       CS_TIME_MOMENT_MEAN,
                                       1000, /* nt_start */
                                       -1,   /* t_start */
                                       CS_TIME_MOMENT_RESTART_AUTO,
                                       NULL);
Posted: Mon Aug 23, 2021 10:17 pm
The code you added should activate the time moment for mean velocity (which can also be done simply with the GUI).
For the mass fluxes, you need the following:
    int moment_f_id[] = {cs_field_by_name("inner_mass_flux")->id};
    int n_fields = 1;
    cs_time_moment_define_by_field_ids("inner_mass_flux_mean",
                                       n_fields,
                                       moment_f_id,
                                       moment_c_id,
                                       -1,   /* t_start */
                                       NULL);
    int moment_f_id[] = {cs_field_by_name("boundary_mass_flux")->id};
    int n_fields = 1;
    cs_time_moment_define_by_field_ids("boundary_mass_flux_mean",
                                       n_fields,
                                       moment_f_id,
                                       moment_c_id,
                                       -1,   /* t_start */
                                       NULL);
Posted: Tue Aug 24, 2021 2:54 pm
by Tsubasa
To output the results, I added the following codes.
cs_field_set_key_int_bits(cs_field_by_name("inner_mass_flux_mean"),
                          cs_field_key_id("post_vis"),
                          CS_POST_ON_LOCATION);
cs_field_set_key_int_bits(cs_field_by_name("boundary_mass_flux_mean"),
However, only the "results.boundary_mass_flux_mean" can be obtained in postprocessing.
Are there some mistakes in the following code?
I wonder why I cannot get the output of "inner_mass_flux_mean" .
void
cs_user_finalize_setup(cs_domain_t   *domain)
	    int n_fields = 1;
	                                       n_fields,
 	                                       moment_f_id,
	                                       moment_c_id,
	                                       1, /* nt_start */
	                                       -1,   /* t_start */
	                                       NULL);
	    int n_fields = 1;
	                                       n_fields,
	                                       moment_f_id,
	                                       moment_c_id,
	                                       1, /* nt_start */
	                                       -1,   /* t_start */
	                                       NULL);
Posted: Tue Aug 24, 2021 6:46 pm
You cannot get the output of a a field defined on internal faces unless you define an output mesh on internal faces, and even then, you need to go through user subroutines. This is mostly intentional, as on any 3D mesh of significant size, you probably do not want to asks you visualization tool to display all internal faces, as this will be cluttered and really swamp your graphics.
If the field seems to appear in the logs, then all should be well. IF you really need to visualize it, you can do so with the cs_user_postprocess_values user-defiend function.
Posted: Tue Aug 24, 2021 8:16 pm
by Tsubasa
OK, I got it.
As you said, visualization of mass flux is not important, but I tried it as a trial.
After I added your code in subroutine, a simulation can be done without errors,
and I found the "inner_mass_flux" and "boundary_mass_flux" in "setup.jog".
Fields of type: postprocess
  Field                    Dim. Location             Id   Type flag
  inner_mass_flux_mean     1    interior_faces       18   48   (postprocess, accumulator)
  boundary_mass_flux_mean  1    boundary_faces       19   48   (postprocess, accumulator)
So next step is to edit the subroutine to read average velocity, average pressure and average mass flux when restarting for the scalar convection?
Tsubasa
Posted: Tue Aug 24, 2021 11:01 pm
Yes, that is the next step.
As some fields are in the main restart file and others in the auxiliary one, renaming migh not work, so the simplest solution is to overwrite the values of the instant fields with the averaged ones (accessing fields by name is simplest) in cs_user_initialization.c or cs_user_initialization.f90.
Posted: Wed Aug 25, 2021 11:03 am
by Tsubasa
Thank you for everything.
Is there a exmaple script to replace the instant value with average value in
https://www.code-saturne.org/cms/sites/ ... e7b6e9cc8a?
Do I need this kind of codes?
  const int kr = cs_field_key_id_try("restart_name");
  cs_field_t *vel = cs_field_by_name("velocity");
  cs_field_set_key_str(vel, kr, "ave_vel");
Actually, I am completely new to C and Fortran, and I've just started to study them.
I would appreciate if you could let me know how to overwrite and tips,
and I am so sorry to disturb you many times.
Hamada
Posted: Thu Aug 26, 2021 4:55 pm
You can try this (in cs_user_time_moments) , but as I was explaining, since the cell velocity and ts time moment are not stored in the same restart file, this might not work (the best solution is to try and check).
If it fails for some fields,
 cs_field_t *vel_m = cs_field_by_name("velocity");
for (cs_lnum_t i = 0; i < cs_glob_mesh->n_cells; i++) {
  vel->val[i] = vel_m->val[i];
would be the solution (in cs_user_initialization.c). With equivalent code (and the correct sizes, n_cells for cells, n_i_faces and n_b_faces for faces) for mass fluxes.
