is there any possibility to use internal surface for head loss definition instead of volume zone? This should represent for example thin perforated plate or filtration fabric.
Michal
Head loss on surface
Re: Head loss on surface
No, I do not think it is possible with the current code. So the best solution is probably to apply the head loss to a thin layer of cells (which assumes your mesh provides for this).
Yvan,
thank you for info. Perhaps in the feature it could be interesting part of code.
Michal
Michal
