Error in calculation stage
Tsubasa
Post by Tsubasa »
I've just started to use Code_saturne.
When I tried "Mesh preprocessgin only", with mesh(med 3.3) following problem happend.
Could you help me and give tips to me?
                      Code_Saturne
 Version:   6.0.5
 Path:      /home/tsubasa/Code_Saturne/6.0.5/code_saturne-6.0.5/arch/Linux_x86_64
 Result directory:
   /home/tsubasa/Desktop/test/newmed/RESU/preprocess_20201120-2331
  Preparing calculation data
 Single processor code_saturne simulation.
  Preprocessing calculation
  Starting calculation
  Post-calculation operations
/home/tsubasa/Code_Saturne/6.0.5/code_saturne-6.0.5/arch/Linux_x86_64/libexec/code_saturne/cs_solver: error while loading shared libraries: libhdf5.so.103: cannot open shared object file: No such file or directory
solver script exited with status 127.
Error in calculation stage.
When I tried "Import mesh only", it was suceeded.
Mohammad
Re: Error in calculation stage
Post by Mohammad »
When I installed code_saturne for the first time, I had the similar problem.
The problem solved by using the following command in terminal before running the code:
export LD_LIBRARY_PATH="/usr/local/lib:$LD_LIBRARY_PATH"
Hope it works for you, too.
If it doesn't help, then it maybe due to HDF5 library which may not be installed, or given to code_saturne correctly.
Mohammad
Tsubasa
Post by Tsubasa »
Dear Mohammad,
Thank you for your advice.
Your tip corrected my error.
Thank you.
