I am trying to preprocess a mesh in CGNS format to generate a 'mesh_input'
But it comes out such error:
Code_Saturne is running
Version: 4.0
Path: /home/xq/Softwares/saturne_4.0.2/code_saturne-4.0.2/arch/Linux_x86_64
Result directory:
/home/xq/TESTs/Channel_TEST/CASE1/RESU/20200626-0206
Preparing calculation data
Preprocessing calculation
File "/home/xq/Softwares/saturne_4.0.2/code_saturne-4.0.2/arch/Linux_x86_64/bin/code_saturne", line 76, in <module>
retcode = cs.execute()
File "/home/xq/Softwares/saturne_4.0.2/code_saturne-4.0.2/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_script.py", line 88, in execute
File "/home/xq/Softwares/saturne_4.0.2/code_saturne-4.0.2/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_script.py", line 150, in run
File "/home/xq/Softwares/saturne_4.0.2/code_saturne-4.0.2/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_run.py", line 304, in main
save_results=save_results)
File "/home/xq/Softwares/saturne_4.0.2/code_saturne-4.0.2/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_case.py", line 1764, in run
force_id)
File "/home/xq/Softwares/saturne_4.0.2/code_saturne-4.0.2/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_case.py", line 1504, in prepare_data
d.preprocess()
File "/home/xq/Softwares/saturne_4.0.2/code_saturne-4.0.2/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_case_domain.py", line 758, in preprocess
retcode = run_command(cmd, pkg=self.package)
File "/home/xq/Softwares/saturne_4.0.2/code_saturne-4.0.2/arch/Linux_x86_64/lib/python2.7/site-packages/code_saturne/cs_exec_environment.py", line 516, in run_command
p = subprocess.Popen(cmd, env = env, **kwargs)
File "/usr/lib/python2.7/subprocess.py", line 711, in __init__
errread, errwrite)
File "/usr/lib/python2.7/subprocess.py", line 1343, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
Could anyone teach me how to solve this problem?
Error in mesh preprocess
Re: Error in mesh preprocess
Problem solved:
if you set disable_frontend =yes when installing using install_saturne.py ( automated installs )
~/.../libexec/cs_proprocess will not be installed
This is why the error "No such file..." occurs
