Is there a reason why the attached xml file gives the error "Expressions are missing !" when you try to save it? In fact the file has nothing changed from the default except for creating an inlet with a prescribed "norm (user law)" and specified coordinates for the direction.
Am I making an obvious mistake? At a minimum the error is not very informative (particularly because the file does save, and it will allow a simulation to run -- I can send the more complete case this is based on to anyone interested).
Breaking the GUI
Breaking the GUI
- break_cs.xml
- (4.62 KiB) Downloaded 167 times
Re: Breaking the GUI
I download your xml and can't reproduce you error. I make some changes and save it without any error or warning.
What version of CS are you using?
Version: 6.1-alpha-3d40cb102
Ah, okay, apparently it was just a temporary bug ; some earlier and more recent versions work fine.
