how does it works to set up a constant value for the thermal expansion coefficient?
Marco
Re: thermal expansion coefficient
First of all you have to activate the thermal model, then in the fluid property tab change density from constant to user law. In the mathematical expression editor you can write an equation for the density which include the thermal expansion coefficient, like the Boussinesq approximation for buoyancy.
Don't forget to set the gravity vector.
Hi thanks Luciano it could be usefull.
I am using AFM for temperature and in code saturne v4 I have divrit.f90 in which beta is called in this way
if (ibeta.gt.0) then
call field_get_val_s(iprpfl(ipproc(ibeta)), cpro_beta)
endif
and then it is used in AFM formulation.
! AFM and EB-AFM models
! "-C_theta*k/eps*( xi* uT'.Grad u + eta*beta*g_i*T'^2)"
if (ityturt(iscal).eq.2.and.ibeta.gt.0) then
if (itt.gt.0) then
temp(ii) = temp(ii) - ctheta(iscal)*xtt* &
etaafm*cpro_beta(iel)*grav(ii)*cvara_tt(iel)
I didn't find anything in code saturne v6 so do you know how to set up and check it in the newest version?
Anyway do you think that changing beta in the density law will change also for AFM model?
Marco Santucci
endif
if (itt.gt.0) then
Marco Santucci
In the file /turb/divrit.f90 are the same lines that you mention,
So, I think that you can use in the same way that in CS 4.
! AFM model
if (iturt(iscal).eq.20) then
if (itt.gt.0.and.ibeta.ge.0) then
endif
Ok thanks.
So how can I change the value of ibeta?
Kind regards,
Marco
Kind regards,
Marco
