Dear code saturne developpers/users,
I came across to an article about the cooling tower simulation : https://www.code-saturne.org/cms/commun ... ling-tower
However the article is not available online. Could you share it with us?
I also found some fractions of source codes on the git about this cooling tower, without much explanation. Could you share an example here?
I am wondering if I can couple it with some chemical reactions.
Thank you.
Zhenlan
Cooling tower model
Re: Cooling tower model
I am not sure I have a copy of a preprint of the article that I can share on the forum but I will check.
I'll remind colleagues who may have test cases available to check your post.
