How can I get the derivatives of velocity field?
I want to calculate the derivatives of velocity field and store them.
For example, I want this expression in every iteration:
(∂u/∂y + ∂v/∂x)
How can I get this expression from the code?
(∂u/∂y + ∂v/∂x)
Re: How can I get the derivatives of velocity field?
You can get a gradient of a field(scalar, vector or tensor) by using the following Code_Saturne functions:
cs_field_gradient_scalar()/cs_field_gradient_vector()/cs_field_gradient_tensor() in C language
or call field_gradient_scalar() in fortran 90.
The following link of Code_Saturne documentation web site shows how to get the gradient of the temperature field:
https://www.code-saturne.org/cms/sites/ ... nce_p.html
Jamal
Jamal
Thank you Jamal!
Now, the problem is how to get each component of calculated gradient to sum the mentioned expression?
(∂u/∂y + ∂v/∂x)
(∂u/∂y + ∂v/∂x)
I can't see your attached images.
Jamal
Jamal
If you can't see, I want (∂u/∂y + ∂v/∂x)
It's one of strain rate matrix components.
If you take a look at the link provided, you will see some source code such as :
In this case, the gradient of a scalar is a vector. Grad(1,iel) is the gradient in direction X inside cell iel. Grad(2,iel) for direction Y. Grad(3,iel) for direction Z.
EDIT: for the gradient of the velocity field, take a look here : https://github.com/code-saturne/code_sa ... til.c#L744
Cédric
call field_gradient_scalar (ivarfl(ivar), 0, imrgra, inc, iccocg, grad)
! - Compute reconstructed value in boundary cells
do ifac = 1, nfabor
iel = ifabor(ifac)
treco(ifac) = cvar_scal(iel) &
+ diipb(1,ifac)*grad(1,iel) &
+ diipb(2,ifac)*grad(2,iel) &
+ diipb(3,ifac)*grad(3,iel)
Cédric
Thank you!
I used those codes to sum the three components of gradient of velocity field at each point.
So I wrote the following C code in cs_user_postprocess.c file.
But it does not give me any output at all!
My CS version is 5.0.9.
I also included the following headers:
The other question is :
gradv[iel][0][2] means du/dz or dw/dx?
void
cs_user_postprocess_values(const char *mesh_name,
int mesh_id,
int cat_id,
cs_probe_set_t *probes,
cs_lnum_t n_cells,
cs_lnum_t n_i_faces,
cs_lnum_t n_b_faces,
cs_lnum_t n_vertices,
const cs_lnum_t cell_list[],
const cs_lnum_t i_face_list[],
const cs_lnum_t b_face_list[],
const cs_lnum_t vertex_list[],
const cs_time_step_t *ts)
/* cs_lnumt is local mesh id*/
cs_real_t *s_cell;
cs_real_33_t *gradv; //
BFT_MALLOC(s_cell, n_cells, cs_real_t);
BFT_MALLOC(gradv, n_cells, cs_real_33_t);
cs_field_gradient_vector(CS_F_(u),
false, //use_previous_t,
CS_GRADIENT_ITER, //gradient type
CS_HALO_STANDARD, //HALO type
1, //inc
gradv);
for (cs_lnum_t i = 0; i < n_cells; i++) {
cs_lnum_t iel = cell_list[i];
s_cell[i] = (gradv[iel][0][0] + gradv[iel][1][1] + gradv[iel][2][2]);
cs_post_write_var(mesh_id,
CS_POST_WRITER_ALL_ASSOCIATED, /* writer id filter */
"ugrad", /* var_name */
1, /* var_dim */
true, /* interlace, */
false, /* use_parent */
CS_POST_TYPE_cs_real_t, /* var_type */
s_cell, /* cel_vals */
NULL, /* i_face_vals */
NULL, /* b_face_vals */
ts);
BFT_FREE(s_cell);
#include "cs_gradient.h"
#include "cs_halo.h"
Do you have other outputs active ? What system are you running on ? (i.e. some users have had issues with user functions not being called on Ubuntu systems). Your code looks OK, so I do not see any obvious mistake (but there can always be a subtle one).
Could you use a "printf" or bft_printf" statement (or even better, a debugger) to check if the function is called (as it should be) ?
As for the second question, I am not sure. I think it is du/dz judging by a quick look at a usage pattern in the sources, but I recommend checking the sources more carefully, or checking on a case where you are sure nothing interesting happens in the x or z direction (i.e. the matching component is 0).
Thanks for your helps,
I'm using Ubuntu 18.04.
It seems that the problem solved by using cs_field_gradient_scalar instead of cs_field_gradient_vector!
But I have a new problem:
When the calculation ends, the CS says:
After checking listing and error files there is an error there which says:
The outputs are generated perfectly and I can access the results using paraview ,but what about this error?!
How can the results be generated while this error is occurred?
Thank you!
Saving calculation results
Error in calculation stage.
IGSEGV signal (forbidden memory area access) intercepted!
1: 0x7f1e920b9818 <+0x312818> (libsaturne.so.5)
2: 0x7f1e8f5dbecf <GOMP_parallel+0x3f> (libgomp.so.1)
3: 0x7f1e920c68c8 <+0x31f8c8> (libsaturne.so.5)
4: 0x7f1e920caac4 <cs_gradient_scalar+0x334> (libsaturne.so.5)
5: 0x7f1e91eb8757 <cs_field_gradient_scalar+0x127> (libsaturne.so.5)
6: 0x5582d41cc6bc <cs_user_postprocess_values+0x8c> (cs_solver)
7: 0x7f1e91ee7c82 <cs_post_time_step_output+0xaa2> (libsaturne.so.5)
8: 0x7f1e91ee8801 <cs_post_write_vars+0x11> (libsaturne.so.5)
9: 0x7f1e91e40921 <caltri_+0x208c> (libsaturne.so.5)
10: 0x7f1e91e1d58d <cs_run+0x57d> (libsaturne.so.5)
11: 0x7f1e91e1cee5 <main+0x125> (libsaturne.so.5)
12: 0x7f1e90f68b97 <__libc_start_main+0xe7> (libc.so.6)
13: 0x5582d41cc2ba <_start+0x2a> (cs_solver)
Thank you!
If you are running in parallel, you need to allocate using n_cells_with_ghosts and not n_cells..
If this is not the cause of the crash, running under a debugger or under Valgrind would help.
