Could anybody give me a hint on how to create a probe showing the maximum y+ value on a wall boundary condition, during a simulation?
Daniele
probe of maximum y+ on wall
Re: probe of maximum y+ on wall
I am am not sure what you need. A probe is usually in a fixed point (except for a moving mesh).
If you need a true probe (or a profile, which is seen as a special set of probes, which are ordered and with an associated curvilinear coordinate), you can use a boundary probe or profile, as described here: https://www.code-saturne.org/cms/sites/ ... bes_p.html
If you need to find the point where the maximum occurs at each time step (not a probe) and print that, use example 6 here https://www.code-saturne.org/cms/sites/ ... ons_p.html. There is an equivalent operation in the C version (we will move to the C version only in future releases, though 6.0 still has a C version).
Thank you for your help. Actually, I am just trying to output the maximum y+ value on a wall during the simulation, in order to check if it is lower than 1, for instance.
I would like to have something like a two column file, with one column being the time and the other the y+ value, for example.
I am trying to do that using the "cs_user_postprocess_values". Do you think this could be the right way?
Thanks in advance.
Daniele
Thanks in advance.
Daniele
No, the cs_user_postprocess_values is intended to allow builtin "on-the-fly" expressions and outputting them on meshes or probes.
For a maximum on the mesh, whose coordinates may vary, the second link in my previous post will be a closer solution. Once you have a value, you can either log it directly to "listing"/"run_solver.log" or open a dedicated file and output it there (see for example cs_user_extra_operations-turbomachinery.c in C or cs_user_extra_operations-richards_flux.f90 in Fortran for this part).
